The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
Get the free JMP Student Edition for qualified students and instructors at degree granting institutions.
View Original Published Thread
Semicon wafer map plot. How to I fix error?
DecileIbex201
// Function to recode a selected column
recode_column = Function({dataTable, columnToRecode, newColumnName},
    // Check if column exists
    If(Column(dataTable, columnToRecode) != {},
        // Create a mapping for recoding
        aa_recode = Associative Array();
        For(i = 1, i <= N Row(dataTable), i++,
            aa_recode[Column(dataTable, columnToRecode) << Get Value(i)] = Column(dataTable, columnToRecode) << Get Value(i);
        dataTable << New Column(newColumnName, Character, Nominal, << Set Each Value(
            aa_recode[Column(dataTable, columnToRecode)]
        cols = {};
        For(i = 1, i <= N Col(dataTable), i++,
            cols[N Items(cols) + 1] = Column(dataTable, i) << Get Name
        recodeColListBox << Set Items(cols);
        colorColListBox << Set Items(cols); // Refresh heatmap plotting list
        Show Message("Column recoded and new column added: " || newColumnName);
        Show Message("Selected column does not exist.")
// Function to plot the heatmap
PlotHeatmap = Function({dataTable, colorColumnName},
    If(colorColumnName != "",
        Graph Builder(
            Size(1500, 800),
            Show Control Panel(0),
            Data Table(dataTable),
            Variables(
                X(:x_Location),
                Y(:y_Location),
                Color(Column(dataTable, colorColumnName))
            Elements(Heatmap(X, Y, Legend(4)))
        Show Message("Please select a column for color.")
list = {};
For(i = 1, i <= N Table(), i++,
    list[i] = Data Table(i) << Get Name
// Create the window
win = New Window("JMP ADDIN",
    H List Box(
        V List Box(
            Panel Box("Choose a source data table",
                dtListBox = List Box(list, max selected(1))
        Button Box("Get Columns",
            chosen = Data Table((dtListBox << Get Selected)[1]);
            If(chosen != {},
                cols = {};
                For(i = 1, i <= N Col(chosen), i++,
                    cols[N Items(cols) + 1] = Column(chosen, i) << Get Name
                colorColListBox << Set Items(cols); // Refresh for heatmap plotting
                Show Message("Please select a valid data table.")
        // Panel for selecting columns to recode
        V List Box(
            Panel Box("Select Columns for Recode",
                recodeColListBox = List Box("")
        // Button to recode a column
        Button Box("Recode Column",
            recode_col = recodeColListBox << Get Selected;
            If(recode_col != "",
                new_col_name = "Recode_" || recode_col; // Define new column name
                recode_column(chosen, recode_col, new_col_name);
                // Refresh column list after recoding
                cols = {};
                colorColListBox << Set Items(cols); // Ensure the new column is available for heatmap plotting
                Show Message("Please select a column to recode.")
        // Panel for selecting columns to plot heatmap
        V List Box(
            Panel Box("Select Columns for Heatmap",
                colorColListBox = List Box("")
        // Button to plot the heatmap
        Button Box("Plot Heatmap",
            selectedColorColumn = colorColListBox << Get Selected;
            If(selectedColorColumn != "",
                If(chosen != {},
                    PlotHeatmap(chosen, selectedColorColumn);
                    Show Message("Selected data table is invalid.")
WorkFlow: Select Table--> Select Column to Recode--> Recode column(need help to allow recoding for both character and numerical column)--->Refresh column list--> select one or many columns --> Plot Heat Map
Need Help 1) debug the currect script where i can recode only numeric data type columns
2) How to include selection of Character type columns to recode?
3) Can I otherwise open the recode ui preset by jmp(columns--> Recode) as part of the ui?
17 REPLIES 17
Re: Semicon wafer map plot. How to I fix error?
This code looks like it has been created by some LLM so there are plenty of small mistakes and utilization of functions which JMP doesn't have. Could you provide an example table which also contains the correct result and explanation where it is coming from.
This the example- you recode 'lot no' to group it and the plot heat map using the 'recoded column'
Example 2: testers are grouped and then the Heatmap is plot using the recoded column
Hope this helps
Thanks
What is the grouping based on? Consecutive rows?
Yes or using the recoded column
Eg where :recoded column=1( thus grouping tester 1 and 2)
I'm still not sure how tester 3 is supposed to turn into 2 or what type of heatmap you are looking from just these two columns
recoded column can be placed as page(:recoded column) I need help on how to trigger recode of selected column and then add it to list of columns when refreshed
So you wish to have an UI which is able to
  • Let user select column(s)
  • Trigger JMP's recode platform on the selected column(s)
  • Prevent user from using in-place operation
  • Detect which new columns were created
  • Create plot based on the newly created columns
Yes!
This might not be as simple as you think if you want to let users freely use the recode platform.
