Stijnw91
Selecting duplicates from different source columns
I'm trying to select (and delete) duplicates after combining two data tables with a source column, I have 2 criteria for a selection:
-The duplicate values should match in 2 columns (Match :col1, :col2), works fine.
-The duplicate values should not have the same value in the generated source column.
I'm not sure how I can code the 2nd criterium, is there some simple != line or 'does not' match ':Source Table'?
dt1 << concatenate (dt1, dt2, append to first table(1), Create Source Column ) ;
dt1 << Select Duplicate Rows (Match (:col1, :col2)) ;
dt1 << Delete Rows();
Re: Selecting duplicates from different source columns
I think you need to take a different approach.  Your submitted JSL has a couple of issues, and a misinterpretation of the Select Duplicate Rows function.
Your Concatenation statement creates a new data table where your data table dt1 is replicated twice in the output table.
The Select Duplicate Rows function only finds duplicates within the same column.
I suggest you look into using the Join platform, which has the capability of determining which rows between the 2 data tables have duplicate values.
Here is an example of comparing between 2 data tables and finding that the person named Robert is in both tables.
dt1 = New Table( "one",
	Add Rows( 20 ),
	New Column( "name",
		Character,
		"Nominal",
		Set Values(
			{"KATIE", "LOUISE", "JANE", "JACLYN", "LILLIE", "TIM", "JAMES", "ROBERT", "BARBARA", "ALICE",
			"SUSAN", "JOHN", "JOE", "MICHAEL", "DAVID", "JUDY", "ELIZABETH", "LESLIE", "CAROL", "PATTY"}
dt2 = New Table( "Two",
	Add Rows( 20 ),
	New Column( "name",
		Character,
		"Nominal",
		Set Values(
			{"FREDERICK", "ALFRED", "HENRY", "LEWIS", "EDWARD", "CHRIS", "JEFFREY", "MARY", "AMY", "ROBERT",
			"WILLIAM", "CLAY", "MARK", "DANNY", "MARTHA", "MARION", "PHILLIP", "LINDA", "KIRK", "LAWRENCE"}
dt3 = dt1 << Join(
	With( dt2 ),
	Merge Same Name Columns,
	By Matching Columns( :name = :name ),
	Drop multiples( 1, 0 ),
	Include Nonmatches( 1, 1 ),
	Preserve main table order( 1 ),
	Output Table( "together" )
dt3 << select where( :Match Flag == 3 );
//dt3 << Delete Rows();
//dt3 << delete columns(match flag);
	Add Rows( 20 ),
	New Column( "name",
		Character,
		"Nominal",
		Set Values(
	Add Rows( 20 ),
	New Column( "name",
		Character,
		"Nominal",
		Set Values(
dt3 = dt1 << Join(
	With( dt2 ),
Stijnw91
Thanks Jim, this works well!
Happy to learn more about the Join function.
Regards,
Stijn
