ih
Super User (Alumni) ih
Select values from report table or clipboard in local data filter
Is there a way to interactively select values from a table (data table or table in a report) and transfer those into a local data filter?
Asking another way: it is straight forward to get values into a one-per-line list into the clipboard, can those be somehow selected in local data filter, or is there an alternate way to do this?
Here is an example workflow:
Re: Select values from report table or clipboard in local data filter
There may be better ways to do this, but here is my take on it.  If you create a separate window, with just a Button Box() in it, clicking on the button will run a simple script that can change the filter
Here is the script that produces the above example
dis = dt << Distribution( continuous Distribution( Column( :height ) ) );
lf = dis << Local Data Filter( Add Filter( columns( :name ), Mode( Show( 1 ), Include( 1 ) ) ) );
nw = New Window( "Set Values",
	Button Box( "Click to Set Selection From Selected Rows",
		theRows = dt << get selected rows;
		If( N Rows( theRows ) > 0,
			theWhere = ":name == \!"" || dt:Name[theRows[1]] || "\!"";
			For( i = 2, i <= N Rows( theRows ), i++,
				theWhere = theWhere || " | :name == \!"" || dt:Name[theRows[i]] || "\!""
			lf << delete all;
			Eval( Parse( "lf << add filter (Columns (:name), where( " || theWhere || " ) );" ) ),
			lf << delete all;
			lf << add Filter ( Columns (:name));
			lf << delete all;
			lf << delete all;
Another thought,
This could be automated by applying a Row State Handler on the data table.  Anytime a rowstate changed, it would trigger the running of the code that is currently in the Button Box, and update the local filter.
ih
Looks like it will be an add-in with your button-box script to the rescue!
Thank you @txnelson.  Will leave the post 'unsolved' for a bit just in case anyone comes up with no-script solution...
