Kevin
Select multiple local max and min and label in a new column
I have a time-temperature table. There are 6 opeations cycles in the table, and in each cycle, there are mutiple peaks of temperature. I need to find all local max values (peaks) and all local minimums (drops) within each cycle, and label them as cycle1-Peak1, cycle1-Drop1,cycle1-Peak2, cycle1-Drop2......cycle2-Peak1, cycle 2-Drop1.......
 Does anyone how to do that?
Re: Select multiple local max and min and label in a new column
Hi @Kevin,
A similar question for finding peaks in a column was posted here:
https://community.jmp.com/t5/Discussions/find-multiple-peak-values-in-a-column/m-p/62919
Maybe the solution here might be able to help.
Best,
Chris
Chris Kirchberg, M.S.2
www.jmp.com
