This is a modified version that may work for you and that is easy to understand.
You would need a loop over the columns to see, where the character string is in,
and your usage of select and delete was not right.
dt = New Table( "Example",
Add Rows( 3 ),
New Column( "A_Dummy", Character, "Nominal", Set Values( {"xx", "yy", "zz"} ) ),
New Column( "B", Character, "Nominal", Set Values( {"a", "b", "c"} ) ),
New Column( "C_Dummy", Character, "Nominal", Set Values( {"l", "m", "n"} ) )
cols = dt << get column names( string );
delete_lst = {};
For( i = 1, i <= N Items( cols ), i++,
If( Contains( cols[i], "Dummy" ),
Insert Into( delete_lst, cols[i] )
dt << Delete Columns( delete_lst );
Georg
