SamH
Select a group of cells in a column
Hi, I have table with thousands of rows. I need to be able to select a group of cells in one column, so I could copy it into another table. for example for Column: "Test3 (VOLTS)" only I need to copy cells highlighted in yellow from row 4 thru row 18 using JSL code.
Thanks
11 REPLIES 11
Re: Select a group of cells in a column
The point I was making in showing you the last piece of code, was that you can specify a matrix [........] of values (rows) that you can use to select the rows you want.  There are a multitude of ways to populate a matrix.  The capabilites of populating matricies are listed in
     Help==Books==>Scripting Guide
Given your current code, I would probably use an Index() function.  It would make the code far more efficient.  Also, using Wait(0); will force the processing to finish the selection before moving on, rather than having to guess on how much time you need to wait.
L = N Rows( dt ); // number of rows
//For( i = 3, i <= L, i++,
dt << Select Rows( Index( 3, L ) );
dt << Go To( :Height );
Wait( 0 );
dt << Select Matching Cells();
SamH
Thanks Jim.
Sam
