Search function not being as useful on JMP19
Whenever I wanna search for something on JMP 18, it's pretty easy, as I don't need to remember the order of the characters. For example, on JMP 18 ("Arrhythmia" data sample), I could just type some keywords of the label name:
But this doesn't work on JMP19:
This is extremely annoying. Anyone knows if there's an option that could hot fix this?
Re: Search function not being as useful on JMP19
I think JMP did earlier use Contains Terms as default and it was changed to Contains Phrase (one of the extremely weird default behaviour changes which were made in JMP19...) so you might have to make changes to these
JMP 19: Change Default Column Search from "Contains Phrase"
Yup this works great. Thank you!
Please use the kudo option in the wishlist entry Jarmo referenced below the image. This will help to push for a change back.
/****NeverStopLearning****/
