ashwint27
Graph Builder - Parallel Y axes: error bars vs. bands scaling
I have two columns of numeric-continuous data (Data 1 and Data 2) plotted with the new JMP 19 Graph Builder feature of parallel y-axes, and a grouping column used as the x-axis.  I use the line element and choose mean as the summary statistic.
Adding a Range error interval style of Error Bands on Data 1's data, the Error Bands  appear to be positioned and fixed against the outer y-axis (Data 2's, first chart).  Selecting "Band" interval style (second chart) shows it now tracks to the correct inner y-axis.   Is there a way to get the inner column's Error Bars to track to the correct y-axis when using this feature?  I've attached a data table with this data.
Re: Graph Builder - Parallel Y axes: error bars vs. bands scaling
Very quickly checking seems like a bug to me. Contact JMP Support via email.
@XanGregg
@XanGregg
