Fiona0723
Scripting a Gauge R&R issue
as below JMP script is for Gauge R&R 5 sigma
but in my Variability Chart ,I always got one first item can set up successfully on Gauge RR 5 sigma.
i don;t understand, why i can;t get all of "y list " item on 5 sigma.
anyone can help me?
rezults = Column Dialog(
title( "Select Columns For Gauge R&R Analysis" ),
yycol = ColList( "Y, Response", Mincol( 1 ), DataType( Numeric ) ),
xxcol = ColList( "X, Factor", Mincol( 1 ), Modeling Type( Nominal ) ),
bbycol = ColList( "By" )
ylist = rezults["yycol"];
xlist = rezults["xxcol"];
bbylist = rezults["bbycol"];
N = N Items( ylist );
For( i = 1, i <= N, i++,
s = dt << Get Property( "Spec Limits" );
usl = s["USL"];
lsl = s["LSL"];
obj = Variability Chart(
Y( Eval( ylist ) ),
X( Eval( xlist ) ),
By( Eval( bbylist ) ),
Model( "Main Effect" ),
Max Iter( 100 ),
Conv Limit( 0.00000001 ),
Number Integration Abscissas( 128 ),
Number Function Evals( 65536 ),
Analysis Type( "Choose best analysis (EMS REML)" ),
Historical Mean( 0 ),
Historical Sigma( 0 ),
//Process Variation( 0 ),
Std Dev Chart( 0 ),
obj << Gauge RR( 5, usl - lsl, lsl, usl );
mikedriscoll
Re: Scripting a Gauge R&R issue
Ignore the original version of this reply. I'm going to go with the 'it was before my morning coffee excuse'.
Try this.  A couple corrections. The s, lsl, usl were not stored in a list in previous posts so the values were stale. fixed here. I inadvertantly used the "N" as the iterating parameter instead of i. Fixed here. Definitely double check this is doing what you want.
//clear log();
namespace("here")<<remove(namespace("here")<<getkeys);
names default to here(1);
dt = current data table();
showErrorMsg = expr(New Window("Must select at least one column...",<<Modal, textBox("Must select at least one column in Y and X roles.               "),
ButtonBox("OK")));
//grrFunction = Function({ylist, xlist, bbylist},    // pass GUI variables to locals here, downside is can't hover to observe values
grrFunction = Function({x}, // x not used here, just using the variables from the GUI and re-assinging to existing vars
    ylist = yParamNames;
    xlist = xParamNames;
    bbylist = byParamNames;
    nwOutput = new window("Output",
        vlb_out = vlistbox();
        s = column(dt, ylist[i]) << Get Property( "Spec Limits" );    // note that I had a typo here, should be i, not N
        usl = s["USL"];
        lsl = s["LSL"];
        //obj = Variability Chart(
        vlb_out << append(
            Variability Chart(
                Y( Eval( ylist[i] ) ),
                X( Eval( xlist ) ),
                Max Iter( 100 ),
                Std Dev Chart( 0 ),
//    obj << Gauge RR( 5, usl - lsl, lsl, usl );
nw = new window("Select Columns For Gauge R&R Analysis",
    hlistbox( // horizontal list box
        cflObj = filter col selector(data table(dt << get name()), nlines(20)),    //first item in hlist box
        panelbox( "Cast selected columns into roles",                        // second item
            lineupbox(ncol(2),
                    bb_y = buttonbox("Y, Response",
                        newParams = cflObj << get selected;
                        yColObj << append(newParams);
                    yColObj = col list box(data table(dt << get name()),numeric,nlines(5), min items(1)),
                    bb_x = buttonbox("X, Factor",
                        xColObj << append(newParams);
                    xColObj = col list box(data table(dt << get name()),nlines(3), min items(1), <<Set Analysis Type(Nominal)),
                    bb_by = buttonbox("By",
                        byColObj << append(newParams);
                    byColObj = col list box(data table(dt << get name()),nlines(3))
            )// end lineupbox
        )// end roles panel box
        panelbox("Actions",                                                    // final item
            vlistbox(
                button box("Ok",
                        yParamNames = yColObj << get items;
                        xParamNames = xColObj << get items;
                        byParamNames = byColObj << get items;
                        if ( nitems(yParamNames) == 0 | nitems(xParamNames) == 0  ,
                            showErrorMsg
                            //else
                            new namespace("recall_grr");
                            recall_grr:yParamNames_rcl = yColObj << get items;
                            recall_grr:xParamNames_rcl = xColObj << get items;
                            recall_grr:byParamNames_rcl = byColObj << get items;
                            nw << close window;
                            //grrFunction(yParamNames, xParamNames, byParamNames)        //pass to local
                            grrFunction(1)        // use these 3 (above) vars directly without passing
                button box("Remove", yColObj << remove selected; xColObj << remove selected; byColObj << remove selected),
                button box("Cancel", nw << close window),
                spacerbox(Size(1,80)),
                button box("Recall",
                    try(yColObj << append(recall_grr:yParamNames_rcl));
                    try(xColObj << append(recall_grr:xParamNames_rcl));
                    try(byColObj << append(recall_grr:byParamNames_rcl));
        )//end actions panel box
    ) // end hlistbox
);//end new window nw
mikedriscoll
You didn't have dt defined but I assume you had it defined separately. But even so, you were using this command in the loop:
This doesn't work (assuming dt is a data table) because the spec limits are a property of a column, not the data table. See below for how to reference the column and access the spec limits property. I've added a dt = current data table() line.
Also, the column dialog() command is deprecated (I think) and replaced by the new window() command which uses a whole host of display boxes including "filter col selector()", "col list box()", and "button box()". If you're just starting out you might consider switching. Up to you, but just consider switching vs creating lots of scripts with deprecated features.
	s = column(dt, ylist[N]) << Get Property( "Spec Limits" );
	usl = s["USL"];
	lsl = s["LSL"];
	Y( Eval( ylist ) ),
	X( Eval( xlist ) ),
	Max Iter( 100 ),
	Std Dev Chart( 0 ),
mikedriscoll
Here's the re-write. If for no other reason the recall feature makes things easier to debug.
Edit: Don't use this version. There are issues with the s, lsl, and usl variables being stale and it also doesn't address the OP's issue.
//clear log();
ButtonBox("OK")));
		usl = s["USL"];
		lsl = s["LSL"];
		Y( Eval( ylist ) ),
		X( Eval( xlist ) ),
		Max Iter( 100 ),
		Std Dev Chart( 0 ),
			lineupbox(ncol(2),
			)// end lineupbox
			vlistbox(
				button box("Ok",
							showErrorMsg
							//else
							nw << close window;
	) // end hlistbox
Fiona0723
thanks for your reply,
but I still meet issue in here
after I ran script then i got variablity Gauge chart then
1 st item on Gauge R&R  = > can show 5K in VC chart. it is correct
but 2nd item on Gauge R&R result => it is showing "6K" in VC chart.
i wnat all of ylist item be caluate 5K in Guage R&R
@mikedriscoll Do you have any better idea in here?
mikedriscoll
//clear log();
ButtonBox("OK")));
        usl = s["USL"];
        lsl = s["LSL"];
        vlb_out << append(
            Variability Chart(
                X( Eval( xlist ) ),
                Max Iter( 100 ),
                Std Dev Chart( 0 ),
            lineupbox(ncol(2),
            )// end lineupbox
            vlistbox(
                button box("Ok",
                            showErrorMsg
                            //else
                            nw << close window;
    ) // end hlistbox
Fiona0723
Amazing and it works.
thanks for your sharing.
