markschahl
Scripting Table Sort by User Defined Column
Warning - scripting newbie @ work. I'm working on a script, a part of which sorts the data table by the user selected column (obtained by ColList selection and Eval List).
This does not work, it brings up the Sort dialog, which I don't want:
dt << Sort( By(_userCol), Order(Ascending), Replace Table);
When I hover over _userCol, the assigned column is shown in the scripting window.  If I use the exact column name, it works without bringing up the Sort dialog:
dt << Sort( By(:Timestamp), Order(Ascending), Replace Table);
How can I script this using the variable _userCol?
pmroz
Re: Scripting Table Sort by User Defined Column
You need to use the column function or the eval function:
dt = open("$sample_data\Big Class.jmp");
_userCol = "age";
dt << Sort( By(column(dt, _userCol)), Order(Ascending), Replace Table);
OR
dt << Sort( By(eval(_userCol)), Order(Ascending), Replace Table);
pmroz
_userCol = "age";
OR
markschahl
Thanks. Solved my problem. Subsequently learned about using As Column(_usercol) when using the column in a formula.
Hello Sir,
Is it possible if i can order the the table by a predefined list instead of ascending or descending order. e.g
 _userCol = "name";
 dt << Sort( By(column(dt, _userCol)), Order(Descending), Replace Table);
instead of the above, i like to order the table by name in a order given by "list" below? list={"BARBARA","ALFRED","CHRIS","ALICE","AMY","CAROL","CLAY","DANNY","DAVID","EDWARD","ELIZABETH","FREDERICK","HENRY","JACLYN","JAMES","JANE","JEFFREY","JOE","JOHN","JUDY","KATIE","KIRK","LAWRENCE","LESLIE","LEWIS","LILLIE","LINDA","LOUISE","MARION","MARK","MARTHA","MARY","MICHAEL","PATTY","PHILLIP","ROBERT","SUSAN","TIM","WILLIAM"};
Well....kind of.
If you set the "Value Ordering" column property for the column you want oredered, and then sort by that column, the resulting sort will be ordered based upong the specified order.
dt:name << set property(
	"value ordering",
	{"ALICE", "BARBARA", "CHRIS", "ALFRED", "CLAY", "DAVID", "EDWARD", "CAROL", "AMY", "ELIZABETH", "DANNY",
	"HENRY", "JACLYN", "JAMES", "JANE", "JEFFREY", "JOE", "JOHN", "KIRK", "LAWRENCE", "JUDY", "FREDERICK",
	"LEWIS", "KATIE", "LESLIE", "LINDA", "MARION", "MARK", "LILLIE", "LOUISE", "MARY", "MICHAEL", "PATTY",
	"WILLIAM", "SUSAN", "PHILLIP", "MARTHA", "ROBERT", "TIM"}
dt << sort( by( :name ), order( ascending ), replace table( 1 ) );
Just got it on another thread.
1. first add list check
Column( Data Table( "Summary" ),"ITEM") << Set Property(List Check, summary_items);
2. Perform table sort.
https://community.jmp.com/t5/Discussions/Custom-Sort-Order/td-p/3119
