Dennisbur
Script
I worked in Excel before JMP, and sometimes when I have the same organize of tables (columns, formulas...) I used "Record Macro."
Is there the same function in JMP where I can save the organization of tables (not analyze the graph)?
Thank you
Re: Script
Please explain what you mean by "organization of tables."
JMP does not have macros or the ability to record one. You can script JMP, though, but that might not be necessary. You might look at the Log, which records most of your actions. You might explore JMP Projects.
Re: Script
Yes. Assuming you have JMP 17, the Workflow Builder is what you're looking for. Here's a quick overview to get you started.
If you have a previous version of JMP, the answer is still a qualified "yes," but involves running your analysis in the GUI, then manually piecing together scripts that JMP automatically made in the background.
