  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
jinsejoseph
Script to do : Subtraction of multiple column
Hi Team,
Need help to  develop one script to do subtraction of multiple column , column name and count is variable,
can change based on analysis,
Need to populate column delta with differences all the value from same row,
sample data as below
expected output:
10 REPLIES 10
jinsejoseph
Re: Subtraction of multiple column
Hi Jim,
Thank you for the help,
solution working fine :)
