Mcc99
Script to create a new data table by subtracting one data table from another.
I have two data tables in my project and am trying to write a script that would like to create a third data table which is the values in table #2 subtracted from table #1. Categorical variable columns and column names are the same in both tables and would need to be the same in table #3. I'm using JMP pro 16.
Re: Script to create a new data table by subtracting one data table from another.
I don't really use projects, but this can give you one idea for the script using Data table subscripting (it assumes both have same amount of rows and columns)
dt = New Table("Untitled 2",
	Add Rows(3),
	Compress File When Saved(1),
	New Column("Column 1", Character, "Nominal", Set Values({"A", "B", "C"})),
	New Column("Column 2", Numeric, "Continuous", Format("Best", 12), Set Values([1, 2, 3])),
	New Column("Column 3", Numeric, "Continuous", Format("Best", 12), Set Values([4, 6, 8]))
dt2 = New Table("Untitled 2",
	Add Rows(3),
	New Column("Column 2", Numeric, "Continuous", Format("Best", 12), Set Values([2, 3, 4])),
	New Column("Column 3", Numeric, "Continuous", Format("Best", 12), Set Values([8, 12, 18]))
dt3 = dt2 << Subset(All Rows, Seleted Columns(0));
cont_cols = dt2 << Get Column Names(Continuous, "String");
dt3[0, cont_cols] = dt3[0, cont_cols] - dt[0, cont_cols];
	Add Rows(3),
	Add Rows(3),
Mcc99
Thanks! This worked well!
