Peng
Script to Save Residuals of Spline Fit
Anyone knows how to write a script to sava residuals (or predicteds) as a new colum for spline fit? It is easy if i do it manually, just need to select Save Residuals in the dropdown red triangle. I know how to write scripts to save residuals as a new column for liner fit using Fit Model. However, I often need to fit time-trend data using standardized x spline fit, and i am not sure if there's a easier way to do so. My final goal is to aquire residuals or predicteds for several varialbles in a loop, so a simple script will help a lot.
Thanks!!
Re: Script to Save Residuals of Spline Fit
Each separate "Fit" that is specified has to have their residuals saved separately.  The substript on the "Curve[]" reference is what handles this.  The example below has a GroupBy(:Sex) which will produce a Fit for Females, "F" and one for Males, "M".  Thus, 2 "Save Residuals" must be issued.
obj = Bivariate(
	Y( :Weight ),
	X( :Height ),
	GroupBy( :sex),
	Fit Spline( 0.1, Standardized )
obj << (Curve[1] << Save Residuals);
obj << (Curve[2] << Save Residuals);
As I was testing out this code for your example.  I discovered that JMP 14 does not work for the Save Residuals for a Spline Fit.  I will be passing that on to JMP Support as a bug.
9 REPLIES 9
You can find these types of syntax in the Scripting Index
     Help==>Scripting Index==>Bivariate==>Bivariate Curve
Here is the scripting index example from that entry
obj = Bivariate(
	Y( :Weight ),
	X( :Height ),
	Fit Polynomial( 3 )
Peng
Thanks Jim! It works. If I need to add "GroupBy" in Bivariate is it posible to save all the residuals? It looks like JMP only keeps the last fit line. Thanks!
obj = Bivariate(
	Y( :Weight ),
	X( :Height ),
GroupBy( :Team), Fit Spline( 0.1, Standardized ) ); obj << (Curve[1] << Save Residuals);
obj = Bivariate(
	Y( :Weight ),
	X( :Height ),
	GroupBy( :sex),
gzmorgan0
Jim,
I noticed the same issue for JMP 14.  JMP support states it is fixed in JMP 14.1 (August?).
Here is a small modification of Jim's script. It creates a single column of residuals. It uses the new (in JMP 13) syntax for multiple subsections of a data table. This is getting the residual columns by row and finding the max (actually it gets the only non-empty value).
obj = Bivariate(
	Y( :Weight ),
	X( :Height ),        GroupBy( :sex),
//Find how many in a group. We know it is 2 for Big Class
summarize(_by = By(:sex));
//Find out how many columns before adding residuals
ncpre = ncol(dt);
_nby  = nitems(_by);
for(i=1, i<=_nby, i++,
  obj << (Curve[i] << Save Residuals);
  wait(0);
idx = ncpre+1::(ncpre+_nby);
//create a single column of residuals
resids = dt << New Column("Weight v Height Spline Residuals",
	Numeric, Continuous,
   << Set Each Value( max(dt[row(),idx]) )
Peng
Thank you all for the solutions!! The syntax for multiple subsections of a data table does not work in JMP12. I read another discussion about returning max value of mutiple rows, a similar method was also appllied for JMP13. Is there a better way to acquire max values across mutiple rows in JMP12? Writing a formula to compare row values for unknown number of rows doesn't seem to be efficient. Thanks!
gzmorgan0
I really like the new JMP 13 table subset reference. However, there still is an easy method to get the values with message Get as Matrix. The key syntax is dt << get as matrix( list | index ).  There is no rowwise max function, but there is VMax function which is a columnwise max.  I tested this in JMP 12.
obj = Bivariate(
	Y( :Weight ),
ncpre = ncol(dt);
_nby  = nitems(_by);
  wait(0);
cmat = Transpose(VMax(Transpose(dt << get as matrix(idx)))); //matrix _nby x nrow(dt)
/*the previous line of code is performing these tasks
  - get the columns of residuals into a matrix of size nrow(dt) x _nby
  - create the transpose: coloumns are rows and rows are columns, size _nby x nrow(dt)
  - Vmax is a vertical maximum, it finds the max of each column (previously rows)
    returns a 1 x nrow(dt) vector, a row vector
  - transpose again so it is a column vector
	Numeric, Continuous, Values( cmat )
Peng
Cool, this is awesome!!
Just one more question:
When I do  obj << (Curve[i] << Save Residuals) and group by (:sex), JMP calculated residuals for "M" and "F" and saved in different columns with some empty cells. That's why "transpose" is needed to get all residuals in one column. However, if I do <<save Predicteds and group by (:sex), it actually calculates Predicteds for all Heights for both "M" and "F". I guess by default JMP does that even if I do it manually in the drop. Is there a way to claculate Predicteds for individual sex only?
Thanks
gzmorgan0
Peng,
Yes, this seems inconsistent, however, I am guessing this is done on purpose to compare the predicteds (for example, the males are a hold-out set for the predicteds based upon females and vice versa.
To create a single column of Predicteds based upon the Group By  model create a new column with a formula or set each value expression
If( :sex=="M", column for the male predicteds, :sex=="F", column for the male predicteds);
If you want a column that looks like the residual columns, then create a columnm for males and use an expression like
If( :sex=="M", column for the male predicteds, empty() );
Then do the same for females.
deveshchugh
Hi Jim
Any resolution/fix to so that we can save residual in v14?
thanks for the help
