shampton82
Level VIII
Script for combining data table scripts with data from multiple files and saving into on JSL file
Hey everyone!
Okay after trying for way to long I am stuck on how to get this code to work.  I am trying to make a script that will allow a user to select from a list of open files, and for each file selected the code will copy the data table scripts and then paste them all into a single JSL file that I can then run at a later time and will open all the data tables again.  Basically like a way to pack a bunch of data tables into a single file (without having to ZIP them) so it is easier to store more complex analysis. This code does most of what I want but I can't get the table scripts to save to a JSL file, they keep wanting to open a copy of the files.
nw = new window("Trial",show menu(0),
	vlistbox(
			hlistbox(
				panelbox("Open data tables",
					lb = listbox(get data table list ());
				panelbox("Data tables to save into one script file",
					lb2 = listbox();
			buttonbox("press to select tables",dtla=lb << Get Selected;lb2 << Append( dtla );  ),
			buttonbox("press to remove tables",lb2 << Remove Selected();  ),
			panelbox("what is the file name?",
					teb1=Texteditbox();
			buttonbox("press to save",
				dtlb=lb2 << Get items;
				fn=teb1 << Get Text();
				list_of_table_scripts={};
				For( i = 1, i <= N Items( dtlb ), i++,
						y = datatable(dtlb[i]) << Get Script With Data Table();
						insertinto(list_of_table_scripts,y);
				Save Text File( "$desktop\"||fn||".jsl", y );
				nw<< Close Window;
teb1<< Set Width( 200 );
Thanks for any guidance!!
Steve
Re: Script for combining data table scripts with data from multiple files and saving into on JSL file
I wouldn't suggest saving data table as a script unless it is very small as the script size can quickly get massive. But if you really want to do this, you could use something like this
dt1 = Open("$SAMPLE_DATA/Big Class.jmp");
dt2 = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
tables = Get Data Table List() << get name;
tablescripts = {};
For Each({tablename}, tables,
	s = DataTable(tablename) << Get Script;
	Insert Into(tablescripts, Char(Name Expr(s)));
Save Text File("$DOWNLOADS/demo.jsl", Concat Items(tablescripts, ";"));
tablescripts = {};
Depending on how you would be using the tables later, you could collect either to JMP Project or to a zip file (both can be done with JSL). You might have to create a separate table loader script if you go this route unless you wish to use the files from JMP Project. I don't personally like their implementation at all so I tend to avoid them, but I have used them from time to time to package JMP files for archiving purposes.
shampton82
Level VIII
@jthi , what would be the JSL for saving to a ZIP file?  I don't see anything in the scripting index.
I think you have to save your tables temporarily so you can load them as blobs
dt << Save("$TEMP\blob.jmp"); // save jmp table to load it as a blob
Close(dt, no save);
b = Load Text File("$TEMP\blob.jmp", blob);
za = Open("$TEMP\deleteMe.zip", zip);
za << Write("Big Class.jmp", b);
Delete File("$TEMP\blob.jmp");
There are quite a few improvements which could be added here.
shampton82
Level VIII
Thanks @jthi !
Added your code to mine and this works great!!  Thanks for the heads up on file size, I will have to keep an eye on that.
	vlistbox(
			hlistbox(
					lb2 = listbox();
					teb1=Texteditbox();
				tablescripts = {};
				For Each({tablename}, dtlb,
				Save Text File( "$desktop\"||fn||".jsl", Concat Items(tablescripts, ";") );
				nw<< Close Window;
