Ake
Ake
Script for Group by and Fit each value
I have a script in the Custom toolbar that turns character columns into numeric, which I use all the time.
I also use Group by and Fit each value whenever I have a suitable graph ready.
Now I want a script that, when I already have an x-y graph, does Group by and Fit each value. The below script works as I tried it on Big Class.jmp, but I want it to do just the Group by and Fit each value, on an already existing graph. I guess I need to define obj so that it points to the graph, but how?
dt = Current Data Table();
obj = dt << Bivariate(Y(:Weight), X(:Height));
obj << Group By(:Sex);
obj << Fit Each Value;
Re: Script for Group by and Fit each value
Depending on how robust script you want and with what type of reports you want it to work with, you might have to modify this
rep = Current Report();
obj = rep[OutlineBox(1)] << Get Scriptable Object;
// might have to add check if you have correct type of report open
Ake
Ake
Appears to work wonderfully! Thanks a lot!
Ake
Ake
Give me the little finger and I'll take the hand! That worked so good, that now I would like the same thing to work when I have more than one plot in the report, e.g. when I have plotted more than one parameter or by group. Tried experimenting with 'xPath' that I found in the forum, but no success. Syntax is everything.
Send << get xml message to your object reference (rep in this case). Then from log try to see if there is something what you could use to get access to correct outlineboxes
If you have JMP17 I think helpKey is usually quite good bet. You could also possibly use outlinebox names.
After you have those outlinebox references, modify script as needed
dt = Fit Group(
	Bivariate(Y(:height), X(:age)),
	Bivariate(Y(:weight), X(:age)),
	<<{Arrange in Rows(1)}
obs = rep << XPath("//OutlineBox[@helpKey = 'Bivariate Report']");
objs = obs << Get Scriptable Object;
objs << Group By(:Sex);
objs << Fit Each Value;
