Steven_Moore
Script Question
The following is part of a script I am trying to run. I want to divide my X variable before plotting. I have tried several things, but am not getting it right. Can someone help me?
Graph Builder(
Variables(
X( :Line 160 Cases ),
Y( :Line 160 Broke ),
Wrap( :Month ),
Color( :Month )
Points( X, Y, Legend( 27 ) ),
Line Of Fit( X, Y, Legend( 29 ), Confidence of Fit( 0 ), Equation( 1 ) )
Steve
jerry_cooper
Staff (Retired)
Re: Script Question
Sorry, you need another closed parentheses in the X variable line (I neglected to put it there in the code that I pasted):
           X(  Transform Column( "My X/1000", Formula( :Line 160 Cases / 1000 ) ) ),
Re: Script Question
I do not understand what you are saying when you say that you want to divide your X variable?  Group it in the graph, divide it by some number, split the data into separate subsets?????
Steven_Moore
Re: Script Question
Jim,  I want to divide each X value by 1000 before plotting.  I don't want to create another column and the current X column is being used in formulas for other columns already, so I don't want to have to edit all those formulas.
Thankls!
Steve
jerry_cooper
Staff (Retired)
Re: Script Question
Try this:
Graph Builder(
     Variables(
           X(  Transform Column( "My X/1000", Formula( :Line 160 Cases / 1000 ) ),
           Wrap( :Month ),
           Color( :Month )
Steven_Moore
Re: Script Question
No luck:  I get an error message:  Unexpected end of input.  Perhaps there is a missing "," or ")".  Trying to parse arguments of function "Graph Builder".  Line 21 Column2:)
I typed the code exactly as you have it.  I even copied and pasted, but no luck.
Steve
jerry_cooper
Staff (Retired)
Re: Script Question
Steven_Moore
Re: Script Question
Bingo!!!!  That got it.  Thanks for your help!
Steve
