robot
Update Col List Box
I am trying to create a modal window where a Col List Box is updated based on user selection.  I think this is possible, but I am having trouble with the syntax.  Any suggestions?  I am using JMP12.
// Example.
// Open some data tables.
Open( "$SAMPLE_DATA/Baseball.jmp" );
Open( "$SAMPLE_DATA/Basketball.jmp" );
Open( "$SAMPLE_DATA/Bicycle.jmp" );
// Get list of available tables.
tableList = {};
For( i = 1, i <= N Table(), i++,
       Insert Into( tableList, Data Table( i ) )
New Window( "Select a table",
       <<Modal,
       H List Box(
             Panel Box( "Select dt",
                    getDt = List Box(
                           tableList,
                           Max Selected( 1 ),
                           dt = getDt << Get Selected;
                           Print( dt );
                           // Add some script to update getCol with columns from dt.
                           // I suspect <<Append or <<Set is used, but I cannot get
                           // the syntax correct.
             Panel Box( "Select columns from dt", getCol = Col List Box() )
Re: Update Col List Box
Try this approach:
// Example.
tableList = {};
  <<Modal,
  H List Box(
     getDt = List Box(
       tableList,
       Max Selected( 1 ),
            // delete box that's there, replace with box using the selected table
       getCol << Delete Box();
       pb << Append(
                 // get selected returns a list
                 // you allow only one selected, so there's one item in the list
                 // so the first item in the list is the name of the one selected table
                 Data Table( (getDt << Get Selected)[1] ),
                 // without this, your box is blank
                 "all"
                 // can use this after "all" to restrict the columns to character or numeric
                 //,<<Set Data Type("numeric")
     // give panel box a reference so you can append new col list boxes
   pb = Panel Box( "Select columns from dt", getCol = Col List Box() )
Try this approach:
// Example.
tableList = {};
  <<Modal,
  H List Box(
     getDt = List Box(
       tableList,
       Max Selected( 1 ),
       pb << Append(
                 "all"
robot
Thanks Melanie!
robot
Hi Melanie,
A coworker of mine is using JMP11, where << Delete Box; seems to not work.  Do you know why?  Is there similar function to use for JMP version < 12?
getCol << Delete Box; // Not working for JMP11.
robot
Never mind.  I got it to work with this:
getCol << Delete; // This works for JMP11.
