RaviK
Scatter plot matrix
I am using JMP15.2 and looking at scatter plot matrix. In the older JMP versions, when you did a scatter plot, you would automatically get the full summary. With 15.2, I am not getting the summary.
I did go into Options > Platforms > Scatterplot matrix and turned ON "Full" summary.
Exited JMP, restarted, re-did analysis - still no summary.
Any thoughts/ideas?
Thanks.
RaviK
Re: Scatter plot matrix
Hi Peng,
Yes, that's it. Thank you.
I'm a little confused on what you are looking for. If you go to Graph > Scatterplot Matrix, you will get a scatterplot matrix graph. What do you mean by "the full summary"? I have versions 14, 15, and 16 and they all produce the same output. What are you expecting to see and which prior versions had it?
Dan Obermiller
RaviK
Hi Dan,
Thanks for your response.
I do get the plot outputs. The older JMP versions (9, 10, think) used to spit out R-sq values by default for each correlation.
I dont get those now with 15.2
peng_liu
Could that be Multivariate platform under Analyze menu, rather than Scatterplot Matrix under Graph menu?
RaviK
Hi Peng,
