matthewh
Saving journals as HTML
I would like to create an HTML report from a journal which contains various graphical outputs from JMP platforms.
I have created the journal using:
jrn1 = {cp7, cp4, cp6, cp8, cp9, cp2, cp3 } << Journal Window;
which works fine (cp* is various graphs, tables etc). If I then save this journal as HTML from the file menu, it saves the entire journal with all the graphs displayed correctly in the HTML page as I want it.
However, if I try saving the journal as HTML from JSL using:
jrn1 << Save HTML("C:\data\test.html");
it saves all the individual image files, but the HTML file only contains the last graph displayed in the journal. This also happens if I save the journal as a JRN file then reopen it in JMP.
Is it possible to do this correctly and if so, how do I do this?
Many thanks,
Matthew.
XanGregg
Re: Saving journals as HTML
The Journal Window message doesn't return the created journal, so your jrn1 variable actually just holds a copy of the cp* list. The Save HTML is then sent to each item in that list, each time overwriting the previous. Try instead
Current Journal() << Save HTML("C:\data\test.html");
6 REPLIES 6
XanGregg
ENTHU
I used this approach to save journal as HTML.
Is there a way to open html page in default browser when the script is run?
Thanks
This should work:
Web("C:\data\test.html");
See 'Scripting the Report' in "Sharing Interactive Web Reports in JMP 13" at:
https://community.jmp.com/t5/Discovery-Summit-2017/Sharing-Interactive-Web-Reports-in-JMP-13/ta-p/44...
~John
ENTHU
This works!Thanks
ENTHU
Also I was wondering if there is a way in jsl to combine 2 htmls and display as one report.
Thanks
There are a few ways to combine multiple reports into interactive HTML. Please take a look at:
https://community.jmp.com/t5/Discussions/How-do-I-create-a-html-file-from-output-from-several-JMP-re....
~John
