Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Created:
Jun 4, 2021 08:13 AM
| Last Modified: Jun 8, 2023 5:34 PM(1612 views)
Hi, in the light of open science and reproducibility issues, many journals require the publication of code. Is there a way of generating a document out of JMPGenomics 9 which contains the code for the analysis that was done?
