Djtjhin
Saving JMP File / data table in Sharepoint through JSL
I'm trying to store a jmp data table which I can periodically update through JSL script (e.g. treating it like a check-in, check-out log).
So far, I was able to successfully open the data table using the Open() function. However, instead of opening the actual data table, it downloaded like a temporary copy of the table from sharepoint as I see that the table name became "Untitled $$$".
This is still acceptable as long as I can just save this new table in the same sharepoint directory and write over the existing file. I tried the Save(), Save as(), Copy Location () but none of these functions work.
The errors which I faced are similar to the ones discussed in this thread below:
Save data table to a sharepoint
I wonder if there are any new solutions since 2012.
Appreciate the help
Craige_Hales
Re: Saving JMP File / data table in Sharepoint through JSL
Here's a 2010 article that expands on @pmroz comments.
https://whitepages.unlimitedviz.com/2010/12/unc-path-naming-for-files-stored-on-sharepoint-2/
I'm not a sharepoint user, but it appears you need some software on your machine that makes the http WebDAV stuff from sharepoint appear to be a network file. (Edit: And Isaac has a good comment at the bottom of that blog.)
As far as I know there is no builtin capability for this in JMP.
@briancorcoran
Craige
Craige_Hales
@briancorcoran
Craige
Djtjhin
Thanks for sharing this.
ih
Super User (Alumni) ih
A few links that may or may not have some helpful info, I cannot tell if the errors in your example are the same as was discussed in these more recent posts:
Unable to save file to Sharepoint
How to extract data from an Excel file on Sharepoint?
Open microsoft office 365 cloud-based excel from JMP/JSL?
