lala
Level IX
Save the following as txt with JMP?
How can save txt files without excess "
#title=""
#tooltip="[",2052
#icon="I:\ABC\[.ico"
Thanks!
Re: Save the following as txt with JMP?
You could get the values into a list, convert it to a string and then save that
dt = New Table("Untitled",
	Add Rows(3),
	Compress File When Saved(1),
	New Column("Col",
		Character,
		"Nominal",
		Set Values({"#title=\!"\!"", "#tooltip=\!"[\!",2052", "#icon=\!"I:\ABC\!\[.ico\!""})
vals = dt[0, 1];
str = Concat Items(vals, "\!N");
Save Text File("$TEMP/test.txt", str);
wait(0);
Web("$TEMP/test.txt");
lala
Level IX
回复: Save the following as txt with JMP?
  • This result is incorrect.
	Add Rows(3),
	New Column("Col",
		Character,
		"Nominal",
vals = dt[0, 1];
wait(0);
