DavideGrossi
Save desirability formula from a profiler in the Fit model Platform using JSL
I am trying to automate some JMP analysis where I generate a desirability function using the Fit model platform. With the current JSL code I can launch the fit model platform and add the profiler to the platform, but in the last step I would like to save the associated desirability formula to a new column in the data table and this does not work.
Do you have suggestions on how I should to this? Here is a piece of code similar to what I am using as an example
dt = Open( "$SAMPLE_DATA/Drug.jmp" );
obj = dt << Fit Model(
	Y( :y ),
	Effects( :Drug, :x ),
	Personality( Standard Least Squares ),
	Run Model()
obj << Profiler(1);
obj << Save Desirability Formula;
 Thank you in advance!
Re: Save desirability formula from a profiler in the Fit model Platform using JSL
I'm not sure about the syntax to do it in parts, but this seems to work:
	Y( :y ),
	Run Model()
obj << Profiler(1, Desirability Functions(1), Save Desirability Formula);
First you have to create profiler, then enable desirability functions and finally save the formula.
	Y( :y ),
	Run Model()
DavideGrossi
Thank you very much, this works nicely
