MikeTV99
Save Picture Image Cropped
Hi Folk,
I usually export single plots into images and use in whatever report I am creating. In this instance, a fairly sizeable JOURNAL was created and then saved as PNG. These images are maxing out in the 1700 x 2300 ish range. I tried in a Window and exporting the Window and that did not help. My guess something dumb I am overlooking. My guess is that the real image is 2400 x 3600 ish. I could shrink my plots down of course to fit the width. But, I was hoping there was something I was just not setting correctly.
ErraticAttack
Re: Save Picture Image Cropped
Probably an issue with the monitor switching display scaling -- JMP doesn't work well with that.  The only solution is to restart JMP and keep it in the monitor it started in.
Jordan
