miguello
Can't change FrameBox size when creating report - only when all display boxes AND window created.
All,
I have a script with function that creates a GraphBuilder. It then gets packed into display boxes and put into a new window. Somehow, commands to change FrameBox size from within the function are ignored, and I can only change it when window is created. Why is that? I'd like this functionality to be inside the function, so that it outputs a plot that does not need any additional tinkering with. Changing title works from within the function, why not changing size?
Here's an example with 3 different attempts to change FrameBox size - only the third one works.
X_Parameter = "height";
Y_Parameter = "weight";
groupColumn = "sex";
titleText = "Example";
GBfunction= Function( {dt, X_parameter, Y_Parameter, groupByColumnString, titleText = ""},
	groupByColumn = Column( dt, groupByColumnString );
	cb = Context Box(
		gb = Graph Builder(
			Size( 350, 600 ),
			Ignore Platform Preferences( 1 ),
			Show Control Panel( 0 ),
			Variables( X( Column( X_Parameter ) ), Y( Column( Y_Parameter ) ), Overlay( groupByColumn ) ),
		rgb = gb << Report;
		(rgbOB = ((rgb << XPath( "//OutlineBox[@helpKey = 'Graph Builder']" ))[1])) << Set Title( titleText );
		//Attempt #1
		(rgb << XPath( "(//OutlineBox//FrameBox)" )) << Frame Size( 350, 200 );
		//Attempt #2
		//(rgbOB << XPath( "//FrameBox" )) << Frame Size( 350, 200 );
	Return( cb );
lub = Lineup Box( N Col( 3 ) );
lub << Append( GBfunction( dt, X_Parameter, Y_Parameter, groupColumn, titleText ) );
ob_group = Outline Box( "GB Function example: " || (dt << Get Name) );
ob_group << Append( lub );
nw = New Window( (dt << get name), ob_group );
//Attempt #3
rgb = ob_group << XPath( "//OutlineBox[@helpKey='Graph Builder']" );
//(rgb << XPath( "(//OutlineBox//FrameBox)" )) << Frame Size( 350, 200 );
7 REPLIES 7
Re: Can't change FrameBox size when creating report - only when all display boxes AND window created.
I think changing the frame size doesn't work properly as the frame hasn't yet been visualized, some auto-resizing does take over and there can potentially also be some timing issues.
miguello
I tried setting auto stretching to 0 and stretching to none, obviously, didn't help :(
Figuring out what is forcing the size to be something weird is not always easy. Is there a specific reason why you aren't utilizing Graph Builder's << Size? I know that sometimes it can require some pre-calculations for example when using groups or wrapping
View more...
GBfunction = Function({dt, X_parameter, Y_Parameter, groupByColumnString, titleText = ""}, {Default Local},
	groupByColumn = Column(dt, groupByColumnString);
	cb = Context Box(
		gb = dt << Graph Builder(
			Size(100, 100),
			Ignore Platform Preferences(1),
			Show Control Panel(0),
			//Fit To Window("Off"),
			Variables(
				X(Column(X_Parameter)),
				Y(Column(Y_Parameter)),
				Overlay(groupByColumn)
	rgb = Report(gb);
	(rgbOB = ((rgb << XPath("//OutlineBox[@helpKey = 'Graph Builder']"))[1])) << Set Title(titleText);
	fbs = rgb << XPath("(//OutlineBox//FrameBox)");
	gb << Size(400, 250);
	Return(cb);
lub = Lineup Box(N Col(3));
lub << Append(GBfunction(dt, X_Parameter, Y_Parameter, groupColumn, titleText));
ob_group = Outline Box("GB Function example: " || (dt << Get Name));
ob_group << Append(lub);
nw = New Window((dt << get name), ob_group);
miguello
Yes, there is a reason - I need to mimic the same look and feel that I had in previous iterations of the script that utilized Fit Y by X.
GraphBuilder will change FrameBox size depending on other elements in GB display box - Axis or Legend size, for instance.
At the end these plots will go to a report where the size of the graph area (what exactly the FrameBox is) should be consistent between different plots on the report. That's why.
One option could be to create the new window first
GBfunction = Function({lub, dt, X_parameter, Y_Parameter, groupByColumnString, titleText = ""}, {Default Local},
	cb = Context Box(
			Size(600, 600),
			Variables(X(Eval(X_Parameter)), Y(Eval(Y_Parameter)), Overlay(Eval(groupByColumnString))),
	rgb = Report(gb);
	lub << Append(cb);
	fbs << Frame Size(400, 250);
nw = New Window((dt << get name), Window View("Invisible"), ob_group);
GBfunction(lub, dt, X_Parameter, Y_Parameter, groupColumn, titleText);
nw << Show Window(1);
miguello
You example works as written. However, when I try to implement it in my real-life script, it does resize the FrameBox from Size(350, 600) to something else at the end.
Basically, I have LineUpBox for a reason - I generate several plots in that box, and every third one (or to be precise, every rightmost in each row) has Legend displayed (same for all plots). So when I run it with three plots, the final size of all three FrameBoxes ends up being:
{{350, 220}, {350, 220}, {350, 240}}
instead of {350, 200} that I am trying to resize it to or the initial {350, 600} that GraphBuilder made it with.
I'll try to make a working example that breaks your suggestion later on.
ErraticAttack
This has been a bug forever with GraphBuilder, and there is no easy work-around.  I have an external program that can send notifications back to JMP (it's a localhost server that JMP starts with runcommand) and I feed it a message to ping JMP back in 0.25 seconds, and on that pingback I trigger the forcing of the framesize -- which now occurs after the boxes have all been painted.
Jordan
