sophiaw
Save Multiple Graphs At Once
Hi!
I feel like this should be simple, but I must be missing something. I have a bunch of columns and I want to graph all of them in a loop. I set up the loop so it creates all the graphs, I just can't seem to be able to save them... Here is my code so far:
wind = {};
For(i = 1, i <= nitems(List) - 4, i++,
       wind = New Window(List,
              Distribution(
                     Stack(1),
                    Continuous Distribution(
                            Column(List),
                            Horizontal Layout(1),
                            Vertical(0),
                            Count Axis(1),
                            Normal Quantile Plot(1)
                            Dispatch(
                                   {"Distributions"},
                                   "1",
                                   ScaleBox,
                                   {Min(-0.000151), Max(0.000151), Inc(0.000002), Minor Ticks(1),
                                   Add Ref Line(0.00015, Solid, "Dark Red", "", 1),
                                   Add Ref Line(-0.00015, Solid, "Dark Red", "", 1)}
                            Dispatch(
                                   {"Distributions"},
                                   "Distrib Quantile Plot",
                                   FrameBox,
                                   {Frame Size(622, 207)}
                            Dispatch(
                                   {"Distributions"},
                                   "Distrib Outlier Box",
                                   FrameBox,
                                   {Frame Size(622, 46)}
                            Dispatch(
                                   {"Distributions"},
                                   "Distrib Histogram",
                                   FrameBox,
                                   {Frame Size(622, 504)}
       wind << Save Picture("C:\Users\sophia\Documents\test\", PNG);
The bolded line is the one I'm having a problem with. I was hoping that the new windows would save at the path I assigned, but with the name I have already given it and just add the .PNG.
Thanks for any help!
ms
Super User (Alumni) ms
Re: Save Multiple Graphs At Once
I think the filename must be give explicitly. Try this syntax:
wind[i] << Save Picture("C:\Users\sophia\Documents\test\" || test[i] || ".png", "png");
ms
sophiaw
I was hoping it was something easy to add. That's perfect! Thank you!
vs90
Instead of appending into list(wind), what you can do is create a V List Box() within a window and append into that box by looping over your Distribution.
I was appending multiple control charts into one window by calling Control Chart function every time.
See this if it helps.....
Empty Control Chart Windows..........Weird Situation.
