radhi
Sample Size
Hello
I have a sample of 159 individuals and I want to run an exploratory factor analysis and confirmatory factor analysis using SAS .How much individuals should I consider in ordrer to run both of them ? Is there a rule to choice?What are the SAS command associated?Can we do them by JMP,
Thank you
0 REPLIES 0
