hellind
JSL: Save data table with Compression
current data table() << save("\\fssg52\VIEW21_CHECKLIST.sas7bdat", SAS);
I use the above code to save the JMP data table to SAS data sets. But without compression the data table is very big. How do I put the SAS equivalent of '(Compress=yes)'  in JSL?
mattf
Level V
Hi:
If you also have access to SAS (either local or remote), one work-around might be to comress the file after transferring to SAS with a little post-processing via the SAS Submit command.
e.g.
dt = Open("$SAMPLE_DATA\Big Class.jmp");
dt << Save As("C:\temp\BigClass.sas7bdat", SAS);
// or
dt << SAS Export Data( dt, temp, BigClass, Replace Existing);
// then
SAS Submit("
     libname temp "C:\temp";
     data temp.BigClass(compress=yes);
          set temp.BisClass;
     run;
proc contents data=temp.BigClass;
run;
Best regards,
-Matt
mattf
Level V
Hi:
e.g.
// or
// then
SAS Submit("
          set temp.BisClass;
     run;
run;
Best regards,
-Matt
Re: JSL: Save data table with Compression
How about using the OS file compression?  In Windows NTFS file system, the compression that is built in does a better job of compression than the SAS dataset option.
See http://en.wikipedia.org/wiki/NTFS#File_compression .
Doc Muhlbaier
Duke
hellind
Doc@Duke,
Do you mean compression to ZIP? I save the file in a shared folder to be used by the team.
No, in windows XP and later, the NTFS file system supports data compression at the OS level.  In XP, right click on a file or directory and select properties, click "Advanced" and you get the choice to compress.  You can set it up at the directory level, so all files and subdirectories will be compressed as well.
hellind
I see. I learned something new. I can set compression=on on my local folder.
But because I am saving the datatables as SAS Datasets to a shared folder, controlled my IT, I don't have the option to right click on the shared folder.
My workplace is a corporate with tight security.
