Franck_R
SQL Custom and Eval / Parse (and \!\!\!...)
Hi!
I do a lot of queries that can't use the JMP query builder and have to be written in SQL Custom.
But as I also want to generalize my code I have to integrate a lot of eval / inserts and \!
Here is an example:
Code not yet generalized
New SQL Query(
	Connection(
		"ODBC:blabla"
	QueryName( "v_test_run" ),
	CustomSQL(
		"SELECT \!"t1\!".lot_id
		FROM \!"public\!".\!"v_test_run\!"  \!"t1\!"
		WHERE  (  (  ( \!"t1\!".test_run_timestamp >= '2020-11-01 15:25:11' )  )  ) ;"
) << Modify;
Code Generalized to include a date:
gbStr = Eval Insert("
New SQL Query(
	Connection(
		\!"ODBC:blabla\!"
	QueryName( \!"v_test_run\!" ),
	CustomSQL(
		\!"SELECT \!\!\!"t1\!\!\!".lot_id
FROM \!\!\!"public\!\!\!".\!\!\!"v_test_run\!\!\!"  \!\!\!"t1\!\!\!"
WHERE  (  (  ( \!\!\!"t1\!\!\!".test_run_timestamp >= '^date_deb^' )  )  ) ;\!"
) << Modify;
Eval( Parse( gbStr ) );
Is there any other method that would save me from having to juggle with these \!\!\! symbols?
On complex scripts it's really difficult to handle and debug!
Thank you
ih
Super User (Alumni) ih
Re: SQL Custom and Eval / Parse (and \!\!\!...)
There are a few options outlined in this article, I recommend starting with Eval( Eval Expr()) and then wrapping each piece you need to replace with Expr(), and using \[ ... ]\ to reduce the number of escaped characters.  It could look something like this:
Eval( Eval Expr(
	New SQL Query(
		Connection(
			"ODBC:blabla"
		CustomSQL(
			Expr( "\[SELECT "t1".lot_id
			FROM "public"."v_test_run"  "t1"
			WHERE  (  (  ( "t1".test_run_timestamp >= ']\" || date_deb || "' )  )  ) ;")
	) << Modify
Georg
I like to follow a different path avoiding unintuitive eval parse combinations, where I find them quite useful for other purposes.
Often I have complex queries (built in plain SQL by other Tools like SQL developer). And I Need to modify some variables.
The attached example Shows how it works with big class datatable, howewer it would work for all ODBC Connections in a similar way.
Simply I prepare my Connection string (not used here) and the SQL Query in a string variable, given to the "New SQL Query".object.
I use "assign" (instead of "=") because it works nice for large queries and Code folding.
And I'm more flexible for also using open database function, or processing the SQL in other ways.
Usually the double quotes are not needed in a plain SQL (and I try to avoid also), unless you have names with spaces etc. like "Big Class".
cdt = Open( "$Sample_Data\Big Class.jmp" );
age = "15";
// define custom SQL with placeholder
Assign( sql_str, "SELECT t1.name, t1.age, t1.sex, t1.height,
	t1.weight
FROM \!"Big Class\!"  t1
WHERE  (  (  ( t1.age IN  ( &age )  )  )  ) ;" );
// fill placeholder
Substitute Into( sql_str, "&age", "15" );
// execute query
dt_age = New SQL Query( Version( 130 ), Connection( "JMP" ), JMP Tables( cdt ), QueryName( "aged" || "_" || age ), CustomSQL( sql_str ) ) << Run;
Georg
13 REPLIES 13
ih
Eval( Eval Expr(
	New SQL Query(
		Connection(
			"ODBC:blabla"
		CustomSQL(
	) << Modify
Franck_R
Thank you very much! I had read this article and had tried but I still have difficulties in mastering this eval (eval expr (expr))
ih
I agree that this syntax is only obvious once you understand it, and even then it is confusing.  Check out this wish list item to introduce an Eval Expr First() function, maybe that would be more intuitive?
pmroz
I would use the delimiters \[ and ]\ to include double quotes in the string.
date_deb = "to_date('01-Mar-2019', 'dd-mon-yyyy')";
gbStr = Eval Insert("\[
New SQL Query(
	Connection(
		"ODBC:blabla"
	CustomSQL(
		"SELECT "t1".lot_id
WHERE  (  (  ( "t1".test_run_timestamp >= ^date_deb^ )  )  ) ;"
) << Modify;
write(gbstr);
Output:
New SQL Query(
	Connection(
		"ODBC:blabla"
	CustomSQL(
		"SELECT "t1".lot_id
WHERE  (  (  ( "t1".test_run_timestamp >= to_date('01-Mar-2019', 'dd-mon-yyyy') )  )  ) ;"
) << Modify;
Georg
age = "15";
	t1.weight
// fill placeholder
// execute query
Georg
Franck_R
Great, that's really very useful! And since we've just created the database and I was the main actor of this creation, I've just made sure that no table name or variable name has parentheses or spaces, so it should simplify this generalisation.
ReliabilityWolf
@pmroz I tried the similar thing as above. after custom SQL run, returning the result  is 1 in the end of log. could you please help explain more about the result of 1? is it Eval( Parse( gbStr ) ) return code that you mentioned in your script?
pmroz
Sorry I don't use Query Builder.  I would guess that the return value of 1 is true indicating success.  But that could be a wild surmise :)
ReliabilityWolf
@pmroz thanks for your reply. May I have your support to review the following script?
SQL Query usually takes a few minutes to access database. deleting rows (if :rank >1) sometimes doesn't execute but can do manually. I have no idea.... not sure if my script has any problem?
dt1 = New SQL Query(
	Connection(
		"ODBC:blabla"
	CustomSQL(
		"SELECT "t1".lot_id
) << Run foreground;
write(gbstr);
dt1 << New Column( "Rank", Numeric, "Continuous", Format( "Best", 12 ) );
dt1:Rank << set Formula( Col Rank( :DATE* -1, :ID ) );
dt1 << Row Selection(select where(:Rank > 1 ));
dt1 << delete rows;
