Is it possible to setup a SMTP server to send email through SMTP relay using JSL? See some options on SAS but not sure how to setup using JSL. Thank you
If I read microsoft documentation correctly for Send-MailMessage you can provide it with multiple paths (and I have sent multiple attachments with it using JMP)
