SMTP setup
Ken_K
Is it possible to setup a SMTP server to send email through SMTP relay using JSL?   See some options on SAS but not sure how to setup using JSL.  Thank you
21 REPLIES 21
Re: SMTP setup
In my opinion this type of issues are generally easier to debug within windows commandline or powershell as those are generally issues there, not in JMP (sometimes there are though issues with quoting in JMP).
hcarr01
Re: SMTP setup
Good morning,
Is it possible using your method to modify the body of the email (in -Body)?
For example, being able to write an email with line breaks and spaces?
Example of the email:
Good morning,
Here is the information you will receive:
- info1
- info2
THANKS
This post originally written in French and has been translated for your convenience. When you reply, it will also be translated back to French .
Re: SMTP setup
Have you tried if it works? If I remember it should but you might have to build the body according to Powershell rules (for example https://learn.microsoft.com/en-us/powershell/module/microsoft.powershell.core/about/about_quoting_ru... ).
When I wrote functions to send email in JMP using Send-MailMessage, I did find using -BodyAsHtml easier than just -Body.
hcarr01
Re: SMTP setup
Thank you for your answers !
Can you show an example please?
I already tried something like this
Re: SMTP setup
str = "\[$body = '
Attached to this email
You will find Instructions
Write-Output $body
RP = Run Program(
	Executable("powershell.exe"),
	Options({str}),
	ReadFunction("text")
hcarr01
Re: SMTP setup
Is it possible to add it to the script below please?
In the “orders” section?
commands = {
 "Send-MailMessage -From 'email@address' -To 'email@address' -Subject 'Test mail' -Body 'Message goes here' -SmtpServer smtp.server.com\!n",
 "exit\!n"
icommand = 0;
RP = Run Program(
 Executable( "PowerShell.exe" ),
 ReadFunction( Function( {this}, Write( this << Read ) ) ),
 WriteFunction(
  Function( {this},
   icommand++;
   If( icommand <= N Items( commands ),
    this << Write( commands[icommand] );
    this << WriteEOF;
Re: SMTP setup
str = "\[$body = '
Send-MailMessage -From 'email@address' -To 'email@address' -Subject 'Test mail' -Body $body -SmtpServer smtp.server.com
RP = Run Program(
	Options({str}),
hcarr01
Re: SMTP setup
Great, thank you for your response!
Likewise, is it possible to add special characters to the body of the email?
Re: SMTP setup
Send-Mailmessage has -Encoding parameter Send-MailMessage (Microsoft.PowerShell.Utility) - PowerShell | Microsoft Learn which could work. Or maybe you need those here-strings or convert to html and manage them there.
Edit:
str = "\[$body = @'
Use a quotation mark, like ' or ", to begin a string.
Write-Output $body
RP = Run Program(
	Options({str}),
hcarr01
Re: SMTP setup
Thank you for your reply.
When talking about special characters, I was talking in particular about the “é” or “à” accents.
No recommendations found
