I'm trying to run a few analysis but can't seem to figure my way around JMP to set-up and produce any kind of results. I'm a graduate student in California.
What I know I need to run is:
1) MANOVA - where I am trying to find differences in 4 variables between 4 groups.
2) Multivariate t-test: I have 2 variables, that are related, and find differences between two groups over time.
A little background: I'm observing body composition changes in athletes. for the MANOVA I am trying to see differences between different tissues (the 4 variables, i.e. fat, muscle, bone) between four sports(this is only at one time-point). The multivariate t-test was suggested to look at two types of fat tissue(2 variables) in the body between two sports over a season (beginning and after).
After searching and reading, the MANOVA set up I try to implement in JMP doesn't seem satisfactory, so I run a "Fit Y by X" running 4 one-way ANOVAs. And sources point that I should try to use a 'hotelling T2 test,' which I have no clue how to do on JMP nor have I yet to find any help on this topic or how to set it up.
Any help would be greatly appreciated and if further details are needed I can provide!
