nlc4
Saving a graph as an image file without the "graph builder" header in the image. Can someone please advise?
nascif_jmp
Re: Saving a graph as an image file without the "graph builder" header in the image. Can
I haven't checked the video but the articles don't address the customer need, "Saving a graph as an image file without the "graph builder" header in the image" using a script and not the user interface. The following function does the trick:
save_graph_only = function({gb, pic_file}, {Default Locals},
    rpt = gb << report;
    (rpt << Child) << save picture(pic_file);
Here is a complete example:
Names Default to Here(1);
    rpt = gb << report;
pic_file = "$TEMP/graph_no_outline.png";
dt = Open("$SAMPLE_DATA/Iris.jmp");
gb = dt << Graph Builder(
    Show Control Panel( 0 ),
    Variables( X( :Sepal length ), Y( :Sepal width ), Overlay( :Species ) ),
    Elements(
        Contour( X, Y, Legend( 3 ), Number of Levels( 3 ) ),
        Points( X, Y, Legend( 4 ) )
        Dispatch(
            "Sepal length",
            ScaleBox,
            {Min( 4.02451368343195 ), Max( 8.24903846153846 ), Inc( 1 ),
            Minor Ticks( 0 )}
        Dispatch(
            "Sepal width",
            ScaleBox,
            {Min( 1.75 ), Max( 5.00400457665904 ), Inc( 1 ), Minor Ticks( 0 )}
        Dispatch(
            "400",
            LegendBox,
            {Legend Position( {3, [0, 1, 2], 4, [-1, -1, -1]} ),
            Position( {0, 1, 2, -1, -1, -1} )}
save_graph_only(gb, pic_file);
dt << Close Window();
open(pic_file);
pmroz
Here's a simple way to remove Graph Builder from a graph.  You lose the outline box with the little red triangle.  If you still want the outline box you can replace Graph Builder with a label of your choosing.
dt = open("$sample_data\Big Class.jmp");
Graph Builder(
	Size( 526, 451 ),
	Variables( X( :weight ), Y( :height ), Overlay( :sex ) ),
	Elements( Line Of Fit( X, Y, Legend( 16 ) ), Points( X, Y, Legend( 17 ) ) ),
	SendToReport( Dispatch( {}, "Graph Builder",
			OutlineBox, {Set Title( "" )}
7 REPLIES 7
KarenC
Re: Saving a graph as an image file without the "graph builder" header in the image. Can someone please advise?
If you use the "selection" tool (under the tools menu or the fat plus symbol on your tool bar) you can select just the graph.  You can also click on the graph title to edit (or delete).
Hello nlc4. We have a one-page guide describing how to save out graphics from JMP using the technique that karen@boulderstats has outlined. It is available on our learning library: jmp.com/learn or directly here:
You can also see how to do it in this quick video I captured here:
Connect with me on LinkedIn: https://bit.ly/3MWgiXt
JohnTM
I know this is a really old post, but the link no longer works.  Is there an updated link to follow, and does this include information on removing the title/header from within a script, and not just through the user interface?
stan_koprowski
Hi @JohnTM,
I have updated the links to the content.
cheers,
Stan
nascif_jmp
    rpt = gb << report;
    rpt = gb << report;
    Elements(
        Dispatch(
            "Sepal length",
            ScaleBox,
            Minor Ticks( 0 )}
        Dispatch(
            "Sepal width",
            ScaleBox,
        Dispatch(
            "400",
            LegendBox,
open(pic_file);
pmroz
Graph Builder(
	Size( 526, 451 ),
JohnTM
Thanks to you both pmroz and nascif_jmp!
It is honestly hard to pick one for which solution I like best. The addition of
Dispatch( {}, "Graph Builder", OutlineBox, {Set Title( "" )}),
is a simple one line of added code solution, and if you need the options just add back in a title. Yet nascif_jmp's function example provides the same clean image, but retains the ability to access the options at a later time without needing to remember to change the script if the user is saving the graph scripts back into the data table.
