Jackie_
Run radiobox using jsl
Is there a way to run the radiobox using set?
Tried the following code but doesn't work
New Window( "Example", r1 = Radio Box( {"Red", "Green", "Blue"},
das = r1 << get selected;
if(r1 == "Green",
Caption("Green"))
r1 << set( 2, runscript(1) );
Re: Run radiobox using jsl
Syntax is in Scripting Index and you can use Run Script
but you do have some mistakes in your script (you should use das instead of r1 in comparison)
New Window("Example",
	r1 = Radio Box({"Red", "Green", "Blue"},
		If(das == "Green",
			Caption("Green")
r1 << set(2, runscript(1));
