Eduardo
Run VBA code in JSL script
Hello all!
I'm new to JMP. I've seen many post claiming that it is possible to run a JSL script via Excel VBA. I was wondering if the other way around is possible. Run VBA code inside a JSL script. Reason: I have a macro in Excel and a script in JMP. I would have liked to bring the excel macro to my JMP script. Thanks for info!
Re: Run VBA code in JSL script
You can run a VBScript (which is a subset of VBA and can be used to automate Excel) using JSL's RunProgram.
See my response to this previous community discussion for more details: https://community.jmp.com/t5/Discussions/JSL-Open-a-VBS-script/m-p/36336/highlight/true#M21350
Justin
Byron_JMP
check out this link for basic details:
https://support.sas.com/documentation/onlinedoc/jmp/13.1/AutomationReference.pdf
page 35 has an example of automating JMP from Excel.
Justin
