rj69
How do I calculate a ratio with negative numbers
Without using scripting, I want to create a formula that computes a ratio between two columns of CAGR percentages, taking into account that some of the percentages are negative (meaning simple division will not suffice). A formula that might accomplish this is:formula.JPG
If the above formula would work, how would I incorporate the comma in the JMP formula box? Or, is there a better way to compute the ratio?
Re: How do I calculate a ratio with negative numbers
abs(x-y)/max(abs(x),abs(y))
The functions are available at:
     Help==>Scripting Index==>Functions,
or in the Formula Editor
rj69
Got it. Wasn't sure of the notation for the comma. Thank you.
