Row selection based on multiple columns and multiple criteria
Hey guys,
I read the available threads on row selection but still can't compile a formula to accomplish what I need (sorry - I am VERY inexperienced still..).
I have a table that looks like this:
PersonCompoundDoseUnits
SmithAspirin200mg
SmithAspirin150mg
JonesGabapentin20ug
JonesGabapentin30ug
JonesNyQuil60mL
EdisonMotrin600mg
EdisonMotrin600mg
For each person, I need to look at column Compound and for each Compound, then look at doses and choose the row with higher dose. If one person had used two compounds I need to do dose evaluation for only a comp with multiple doses. So working my way through this table, I should get a new table as below:
SmithAspirin200mg
JonesGabapentin30ug
JonesNyQuil60mL
EdisonMotrin600mg
Can someone please help? Will be very much appreciated!!!!!
pmroz
Re: Row selection based on multiple columns and multiple criteria
You can do this with a tabulation:
PersonCompoundMax
EdisonMotrin600
JonesGabapentin30
NyQuil60
SmithAspirin200
Click on Analyze > Tabulate (JMP 11) or Tables > Tabulate (JMP 10, 9, 8)
Drag Person to the drop zone for rows.
Drag Compound just to the right of Person
Drag Dose on top of N
Drag Max on top of Sum
Click Done
Click the little red triangle and select Make into data table
You might have to normalize the units if that's a consideration.
mpb
mpb
I'm old fashioned and my first impulse is to use the older Tables > Summary approach which is very similar to using Tabulate.
1. Tables > Summary
2. Drag Person, then Compound into the Group box
3. Click Dose and then click the Statistics button and select Max
4. Click OK
or as a script:
dt = current data table();
dt << Summary( Group( :Person, :Compound ), Max( :Dose ) )
Michael
pmroz
PersonCompoundMax
EdisonMotrin600
JonesGabapentin30
NyQuil60
SmithAspirin200
Click Done
mpb
mpb
1. Tables > Summary
4. Click OK
or as a script:
Michael
Jeff_Perkinson
PMroz has a good solution.
Here's another.
Sort your table by Name, Compound, (ascending) Dose.
Then create a Row State column (Cols -> New Column).
And add a Formula.
The formula should be:
Selected State( :Compound != :Compound[Row() + 1] )
In the formula editor it looks like this:
This will select any row where the compound name is different from the compound name in the next row. Since the table is sorted by person, compound, and dose these rows will represent the maximum dose for each person.
You can then copy these selections to the active row state area using the pop-up menu next to the row state column name.
The rows will be selected and you can use Tables->Subset to get a new data table with just the selected rows.
I've attached a data table that shows this.
-Jeff
-Jeff
Byron_JMP
It looks like the logic for selecting the flagged rows might need to be a little more specific?
If( :Person == Lag( :Person, 1 ) & :Compound == Lag( :Compound, 1 ), 0, 1)
Try running this script against the dose table in Jeff's post, then run the sort script first, followed by the subset script.
dt=current data table();
dt<<New Script(  "Sort First",  dt = Current Data Table();  dt << Sort(  replace table,
  By( :Person, :Compound, :Dose ),  Order( Ascending, Ascending, Ascending )););
dt<<New Script(  "subset flagged rows",  dt = Current Data Table();  dt << Select Where( :Flag == 1 );
  dt << Subset(  Output Table( "Subset of dose bw" ),  Selected Rows( 0 ),  Rows( [1, 3, 5, 6] ),  Selected columns only( 0 )););
dt<<New Column( "Flag",
  Numeric,  Nominal,  Format( "Best", 12 ),
  Formula(  If( :Person == Lag( :Person, 1 ) & :Compound == Lag( :Compound, 1 ),
  0,  1  )  ));
Jeff_Perkinson
Byron is right. I was a little too quick and forgot that if two people in sequence are taking the same compound then my condition won't catch the first one.
Here's a corrected formula and data table.
Selected State( :Compound != :Compound[Row() + 1] | :Person != :Person[Row() + 1] )
This time it selects the row if the compound or the person doesn't match the next row.
-Jeff
Thank you, guys!
I tried all three solutions - and got the table I wanted.
It is way simpler than I thought - and I love summary and tabulate functions!!
Thanks again
Tania
