doraemengs
Risk Table of KM plot on JMP?
According to https://community.jmp.com/t5/Discussions/Displaying-at-risk-tables-under-kaplan-meier/m-p/55338/high... , Could you please provide the method for generating a risk table underneath the KM plot? I tried to follow the script from the comment but it was closed to be solved.
dt = Current Data Table ();
minT = 0;
maxT = 25;
stepT = 1;
Summarize( lv = by( :group) );
obj = Survival(
	Y( :time ),
	Censor( :"reject"n ),
	Grouping( :group ),
	Failure Plot( 0 ),
		Dispatch(
			{"Survival Plot"},
			"1",
			ScaleBox,
			{Min( 0 ), Max( 25 ), Inc( 1 ), Minor Ticks( 1 )}
		Dispatch(
			{"Survival Plot"},
			"time",
			TextEditBox,
			{Set Text( "Times(years)" )}
) << report;
obj[List Box( 2 )] << append( Table Box( String Col Box( "No at Risk | Year", lv ) ) );
Tab1 = (obj[lv[1]][Table Box( 1 )] << get);
Tab2 = (obj[lv[2]][Table Box( 1 )] << get);
For( T = minT, T <= maxT, T += stepT,
	lp = Max( Loc( Matrix( Tab1 [years] ) <= T ) );
	AR1 = Tab1["At Risk"][lp];
	lp = Max( Loc( Matrix( Tab2 [years]) <= T ) );
	AR2 = Tab2["At Risk"][lp];
	obj[List Box( 2 )][Table Box( 1 )] << append( Number Col Box( Char( T ), {AR1, AR2} ) );
the out put showed as the attachment picture. Could you please to correct the script?
Thank you
Re: Risk Table of KM plot on JMP?
I attempted to parametrize the code a bit further, does this do what you are looking for if you change minT, maxT, stepT, ycol, grouping and use your table
dt = Open("$SAMPLE_DATA/Rats.jmp");
minT = 100;
maxT = 350;
stepT = 50;
ycol = "days";
grouping = "Group";
Summarize(dt, groups = by(Eval(grouping)));
obj = dt << Survival(
	Y(Eval(ycol)),
	Censor(:Censor),
	Grouping(Eval(grouping)),
	Show Points(1),
		Dispatch({"Survival Plot"}, "1", ScaleBox,
			{Min(minT), Max(maxT), Inc(stepT), Minor Ticks(1)}
rep = Report(obj);
rep[List Box(2)] << append(tb = Table Box(String Col Box("No at Risk ("||ycol||")", groups)));
rep[List Box(2)] << Append(Spacer Box(Size(0,20)));
tabs = {};
For Each({group}, groups,
	Insert Into(tabs, Eval List({rep[OutlineBox(group), Table Box(1)] << get}));
For(T = minT, T <= maxT, T += stepT,
	ARs = {};
	For Each({tab}, tabs,
		lp = Max(Loc(Matrix(tab[ycol]) <= T));
		Insert Into(ARS, tab["At Risk"][lp])
	tb << append(Number Col Box(Char(T), ARs));
Edit: small fixes
11 REPLIES 11
minT = 100;
maxT = 350;
stepT = 50;
ycol = "days";
grouping = "Group";
	Y(Eval(ycol)),
	Censor(:Censor),
	Show Points(1),
rep = Report(obj);
tabs = {};
	ARs = {};
Edit: small fixes
doraemengs
Hi Jarmo, Thank you for your help. It worked!
Best, Theerachai
Here is also a script which can be used basically on Survivor report. It might work in most of the cases but  not sure if it will as I'm not that familiar with this JMP Platform or analysis. I also modified the calculations so they might not be exactly correct
First you have to have Survivor report open
then you can run the script and it will ask for few things
Fill in those and press OK
It will then add the table to your existing report
Script below (and also attached). Use at your own risk, the calculations have not been checked
View more...
/*""" Add risk table to Survival platform
Author: jthi
Creation Date: 2024-07-31
Creation JMP Version: JMP Pro 18.0.1
Description: Based on
	https://community.jmp.com/t5/Discussions/Displaying-at-risk-tables-under-kaplan-meier/m-p/305898/highlight/true#M56162
Todo:
    * Show steps to user before pressing OK
    * Remove modal window
    * Turn into add-in / proper script
    * Add instructions / title to UI
    * Add utility modal
ask_steps = function({}, {Default Local},
	nw = New Window("Fill in Time to Event Steps", << Type("Modal Dialog"), << Return Result,
		H List Box(
			Panel Box("Fill in steps",
				Lineup Box(N Col(2),
					Text Box("Min Time"),
					neb_min = Number Edit Box(.),
					Text Box("Max Time"),
					neb_max = Number Edit Box(.),
					Text Box("Step Time"),
					neb_step = Number Edit Box(.),
					Text Box("Interpolate last"),
					cb_interpolate = Check Box({""}, << Set All(1))
			Spacer Box(Size(20, 0)),
			Panel Box("Actions",
				Button Box("OK"),
				Button Box("Cancel")
		, << Set Window Icon("Survival")
	If(nw["Button"] != 1,
		Throw("Cancelled");
	min_t = nw["neb_min"];
	max_t = nw["neb_max"];
	step_t = nw["neb_step"];
	If(Any(Is Missing(min_t), Is Missing(max_t), Is Missing(step_t)),
		Throw("Steps not filled in");
	interpolate_last = N Items(nw["cb_interpolate"]);
	return(Eval List({min_t, max_t, step_t, interpolate_last}));
add_risk_table = function({platform_ref, min_t, max_t, step_t, interpolate_last}, {Default Local},
	rep = Report(platform_ref);
	dt = platform_ref << Get Data Table;
	ycol = ((rep << XPath("//TextBox[text()='Time to event: ']"))[1] << sib) << get text;
	grouping_col = ((rep << XPath("//TextBox[text()='Grouped by ']"))[1] << sib) << get text;
	Summarize(dt, groups = by(Eval(grouping_col)));
	steps = min_t::max_t::step_t;
	vals = steps;
		m_tb = rep[OutlineBox(group), Table Box(1)] << get as matrix;
		times = m_tb[0, 1];
		atrisk = m_tb[0, N Cols(m_tb)];
		cur_steps = Step(steps, times, atrisk); // Last one isn't assumed in this
		If(interpolate_last,
			If(times[N Rows(times), 1] < max_t & Is Missing(cur_steps[N Cols(cur_steps)]),
				cur_steps[N Cols(cur_steps)] = atrisk[N Rows(times), 1];
		vals = vals |/ cur_steps;
	pb = Panel Box("Risk Table", tb_results = Table Box(
		String Col Box(Eval Insert("No at Risk (^ycol^)"), groups),
	For(i = 1, i <= N Cols(vals), i++,
		cur_vals = vals[0, i];
		title = Char(Remove From(cur_vals, 1)[1]);
		tb_results << Append(Number Col Box(title, cur_vals));
	rep[List Box(2)] << Append(pb);
	rep[List Box(2)] << Append(Spacer Box(Size(0, 10)));
cur_rep = Current Report();
If(Is Empty(cur_rep),
	Throw("No reports open");
ob_ref = cur_rep << XPath("//OutlineBox[@helpKey='Surv']");
If(N Items(ob_ref) == 0,
	Throw("No Surv platform found");
Try(
	{min_t, max_t, step_t, interpolate_last} = ask_steps();
	platform_ref = ob_ref[1] << get scriptable object;
	add_risk_table(platform_ref, min_t, max_t, step_t, interpolate_last);
	Throw("Other issues: " || char(exception_msg));
Write();
Thanks for this script! I really like it. When I generate multiple survival curves at once using the set up below ("Grouping" and "By" specified), the at risk table is only added to the first plot. Is there a way to have it added to all of them?
It should be possible but will require modifications to the script. You can try if this version works for you:
View more...
		H List Box(
				Button Box("OK"),
		Throw("Cancelled");
	vals = steps;
		times = m_tb[0, 1];
ob_refs = cur_rep << XPath("//OutlineBox[@helpKey='Surv']");
If(N Items(ob_refs) == 0,
Try(
	For Each({ob_ref}, ob_refs,
		platform_ref = ob_ref << get scriptable object;
Write();
There are only few changes I did to the end of script, I basically just added one for each loop (and changed one variable name).
Thanks for the quick reply! I am getting this message though?
One s is missing  from line 100
I edited my earlier post to fix the issue
Thank you again! It works now!
To QC the output, I just re-made a reference figure (see below JMP vs reference) and noticed a few details. Starting from the left, at time = 0, the number at risk, 40, is correct, however, subsequent timepoints are inflated by 1. The exception is when the true number is zero, which the script accurately lists. Lastly, there is a 1 at the last timepoint, which should not be there. I could fix this in Excel but would be amazing if there was a scripting fix!
Not sure which calculation is incorrect. If it is in my script, you can most likely fix it somewhere here
I would need example dataset with correct answers to know what the results should be (the interpolate option in my script doesn't seem to work correctly though).
