Andyon98
Returning to original script from which you called a function from in another file.
I have one script to where I want to run code in another file by using:
Include("PATH");
How can I return to the original script and continue with running the code?
Re: Returning to original script from which you called a function from in another file.
When you fall off the end of the included code, the include function will return the value of the last statement executed.
