JMewborn
Col List Box not pulling results when in the same window as a Pareto Plot
I am trying to have a Col List Box to select specifications of a product. When running by itself, the Col List Box works fine, however when I try to add a pareto plot to the same window as a reference for which parts I should or should not pick from the Col List Box, it no longer sends the data selected. I tried with an H List Box as well for the pareto and a separate button to force the desired result but it still had issues. Any help would be greatly appreciated.
GraphingTable = Open( "Vinyl Data.jmp");
//Select the Specs you want to compare by using a COL LIST BOX
ListNumericCols = GraphingTable << Get Column Names(numeric);
show (ListNumericCols);
	SelectCpkSpecs = New Window("Select Specs for analysis", << Modal, << return result,
	Graphing Table << Pareto Plot( Cause( :"Pass/Fail"n ) );
	CpkSpecs = Col List Box (<< Set Items (ListNumericCols))
	CpkSpecNames = SelectCpkSpecs["CpkSpecs"];
show (CpkSpecNames);
Josh
David_Burnham
Re: Col List Box not pulling results when in the same window as a Pareto Plot
Note sure exactly what's going on with your code but here is an alternative representation:
	nw = New Window("Select Specs for analysis", << Modal,
		<<onClose(
			CpkSpecNames = CpkSpecs << get selected
		Graphing Table << Pareto Plot( Cause( :"Pass/Fail"n ) ),
-Dave
David_Burnham
		<<onClose(
-Dave
David_Burnham
I see the problem with your code now : you have a semicolon instead of a comma on the pareto plot line.
-Dave
