SpannerHead
Retrieve a Column Group
I have columns held within groups and I want to be able to reference the group to which each column belongs as a string while I iterate on them.  Is that possible?
Slán
SpannerHead
Re: Retrieve a Column Group
Use << Get Column Group Names to get list of the names and then << Get Column Group to get the list of columns
Edit: If you wish to have strings, loop over the list of columns using Transform Each and then convert them to strings using << Get Name
dt = Open("$SAMPLE_DATA/Cities.jmp");
dt << group columns("xy", {:X, :y});
dt << group columns("pollutants", :Ozone :: :Lead);
colrefs = dt << get column group("xy");
colnames = Transform Each({colref}, colrefs,
	colref << get name
show(colrefs, colnames);
