Tina442
saving multiple reports into one powerpoint
I am aware we can export graphs into powerpoint but having to do this one at a time is a bit cumbersome. I have been attempting to use JSL to recognize all my open reports and export it into one single powerpoint with a for loop and the save presentation() function, but it's not working.
I think I'm having trouble figuring out the function that would recognize all my open windows/reports. Can someone please help?
matth1
Re: saving multiple reports into one powerpoint
Something like Get Window List( Type( "Reports" ) ); might help? E.g.
dist = dt << Distribution(
	Continuous Distribution( Column( :height ), Process Capability( 0 ) ),
	Continuous Distribution( Column( :weight ), Process Capability( 0 ) )
fitxy = dt << Bivariate( Y( :weight ), X( :height ) );
boxp = dt << Graph Builder(
	Size( 528, 448 ),
	Show Control Panel( 0 ),
	Variables( X( :sex ), Y( :height ) ),
	Elements( Box Plot( X, Y, Legend( 4 ) ), Points( X, Y, Legend( 5 ) ) )
winlist = Get Window List( Type( "Reports" ) );
Wait( 0 );
For( i = 1, i <= N Items( winlist ), i++,
	pw = New Window( "output", <<Window View( "Invisible" ), winlist[i] << get picture );
	If( i == 1,
		pw << Save Presentation( "$TEMP/all_reports.pptx" ),
		pw << Save Presentation( "$TEMP/all_reports.pptx", Append )
	pw << close window();
Open( "$TEMP/all_reports.pptx" );
This saves the exact image of the report. To get the typical output with JMP tables, replace pw with winlist[i] in the << Save Presentation lines and delete the lines with pw.
EDIT: the original code left lots of hidden windows called "Output", "Output 2"... sorry.
matth1
	Size( 528, 448 ),
Wait( 0 );
	If( i == 1,
Tina442
That's exactly it! Thanks for the solution, this works perfectly :)
