Rajat
Column Dialog box to select and save column name for selected column
Hi All,
I want to create a dialog box which show all the column names available to the data. It will allow to select the required column and save column name to the variable. So, that I access that column in jsl using the name stored in the variable.
For Example: I have following table.
ABC
johnMath78
AdamScience90
ChrisScience67
If I run the script it will open the dialog (as shown in image) and after selection of column I want to access them using the variable name in which that ccolumn is stored. ( for eg. column(dt,score) )
ian_jmp
Level X
Re: Column Dialog box to select and save column name for selected column
Take a look at this slightly changed code:
NamesDefaultToHere(1);
// Modal dialog: Note that 'ColumnDialog()' is a variant of the deprecated 'Dialog()', so you
// should probably look at 'NewWindow()' with the  '<< Modal' option
dlg = Column Dialog(
			name = ColList( "Name", Min Col(1), Max Col(1) ),
			subject = ColList( "Subject", Min Col(1), MaxCol(1) )
// Stop if the user did not press 'OK'
If( dlg["Button"] != 1, Beep(); Throw());
// Note that 'name' and 'subject' will both be lists - Look at the tooltip when you point to the variable
name = dlg[ "name" ];
subject = dlg["subject"];
// If you require column names . . .
name = Column(dt, name[1]) << getName;
subject = Column(dt, subject[1]) << getName;
Print(name, subject);
ian_jmp
Level X
To get started, use 'Help > Scripting Index' and search for 'Col List Box'. There are three examples.
Rajat
Hi @ian_jmp
I wrote the following code.
			name = ColList( "Name", Min Col(1), Max Col( 1 ) ),
			subject = ColList( "Subject", Min Col(1) ),
		If( dlg["Button"] == 1,
So, After run, when I print the name, it prints ":A". It refers to the whole column but I want to get only the column name. How I can resolve the issue. Also sometime if I am working with multiple data tables it shows error can't access column 'A' because the row number (0) is not valid.
Please help how I can resolve this issue.
Thanks
ian_jmp
Level X
