34South
Reporting of skewed versus normally distributed data?
I am involved in a study which evaluates continuous numerical data across multiple groups. While the numbers of replicates are recognised as being low (n=10 per group), it is not possible to rectify that in this study. Likely due to this, some related (similar in nature) variables, which may otherwise have been normally distributed, are skewed (based on Shapiro-Wilk testing). I do apply non-parametric and parametric tests respectively when evaluating the outcome of each variable between the groups in each case but my question is how to report the data? I have always understood that skewed data is reported as medians and range and normally distributed data as means ± standard deviation. However, when reporting this in a manuscript, this approach looks messy, especially when, as I have suggested, the variables are similar in nature, for example left and right anatomical distances. Can I use means and standard deviations throughout the manuscript, even when in some cases the data is skewed? I would still apply the correct type of statistical test.
P_Bartell
Level VIII
Re: Reporting of skewed versus normally distributed data?
I don't think there is a 'right' or 'wrong' answer here. Recall means and medians are just different measures of central tendency. Standard deviation is but one measure of dispersion. Is there any reason you can't reference both means and medians? After all they are just descriptive statistics. Anyways...I'd tend towards just showing the frequency distributions themselves and let the reader interpret from the pictures themselves, not the mononumerotic 'statistics'.
9 REPLIES 9
P_Bartell
Level VIII
34South
I guess the old statistics adage, "you can do anything, as long as you say what you did", holds! Thanks for providing reassurance that what I propose is acceptable.
I agree with Pete.  I will say, according to Shewhart (Economic Control...P. 94) both the average and the standard deviation are always useful statistics.  Continuing on in that section of his book he finds the measures of skewness and flatness to be of little additional value.
Level XIII
There might be other fields where skewness plays an important role.
Just think of lifetimes, mortality, crime rates, meteors ...
- where outliers in one direction are much more frightening than outliers in the other direction.
You'll have to argue with Shewhart.  Those  comments are directly from his book.
Level XIII
Hm, not easy ...
With some help of Copilot:
A response in the spirit of JMP : )
I have to admit, we drifted away from the original question ...
I love it.  Just goes to show you how wrong AI can be.  The words Special Cause and Common Cause were Deming's.  Shewhart used Assignable and unassignable/chance/random to describe the same.
Level XIII
Thanks, right!
And the term "common cause" was coined by Harry Alpert in 1947?
I don't know why Shewhart used it in this response.
Perhaps he had heard the new terminology and found it useful.
"I don't know why Shewhart used it in this response."
He didn't, that's my point.  You are using some AI to generate what it thinks Shewhart would have said and it is wrong.  Please read Deming's "Out of the Crisis" Chapter 11.
Yes, Dr. Alpert coined the phrase on the subject of riots in prison.
