SpannerHead
Export or Save a Data Table as an Image File
I can see how to readily create an image file from a graph.  Is it possible to do the same with a data table?
Slán
SpannerHead
Re: Export or Save a Data Table as an Image File
Hi @SpannerHead,
Gotcha, let's try it a different way:
pickdir=pick directory();//pick where you want your file to go
dt=current data table();
//clear selections - if the selected column is left it will only bring that column into the journal
dt<<clear select();
dt << Clear Column Selection();
journaltext = (Window( dt )) << getjournal;
journalbox = Journal Box( journaltext );
image = journalbox << getpicture;
//nw=New Window( "image", image );//opening the journal so you can see the appearance-this line isnt needed
image<< Save Image( saveloc=pickdir||"Journalgraph.png", "png" );
open(saveloc);
Thanks,
Ben
6 REPLIES 6
SpannerHead
Looks like I can do this from Journal.  Just need a means to make the code generic to any table?
Slán
SpannerHead
Hi @SpannerHead ,
Here's a generic JSL that will work with any table by sending it over to a journal and saving as you've requested. I've added a prompt at the start so you can pick where you want the file to save.
nw = New Window( "data table journal",<<journal,
placeholder_VLB=v list box());
placeholder_VLB<<append(data table box(dt));
image=nw<<get picture;
open(saveloc);
Thanks,
Ben
SpannerHead
Ben
Clever script!  Only remaining issue is that the resulting Journal loses all it's formatting from the original table.  The original had a lot of colouration indicating pass or fail.
Slán
SpannerHead
Hi @SpannerHead,
dt<<clear select();
open(saveloc);
Thanks,
Ben
SpannerHead
Ben
That works!  Mighty!
Slán
SpannerHead
You can also << get as report + << get picture (<< Get As Report can be helpful in many other places also not just here)
r = dt << Get As Report;
img = r << Get Picture;
img << Save Image("$TEMP/pic.png", "png");
Open("$TEMP/pic.png");
If you wish to access the table box which << get as report does create, you can use << Child on the created display box (it is a border box on highest level)
View more...
r = dt << Get As Report);
tb = r << child;
tb << Set Title Font Style("Bold");
img = tb << Get Picture;
Write();
or data table box (this won't support coloring)
r = Data Table Box(dt);
