guilhem
Replacing missing data by regressed values
Hi
I have a time series for which the variable has missing values. I would like to replace the missing values by a linear model derived from the closest available values in time.
What would be the best way?
And if the script could do that to all the columns of my table (except the time), that would be even better
Thanks
Example
What I have
tOutput
010
10.
2010
What I want:
tOutput
010
115
220
430
1022.5
20
10
22 REPLIES 22
ron_horne
Re: Replacing missing data by regressed values
try this for starters
Imputation Addin
guilhem
Thanks Ron but I don’t see anything in this that does interpolation?
here is a script that will do the task
For( rows = 1, rows <= N Rows( dt ), rows++,
       If( Rows == 1, counter = 0 );
       If( Is Missing( dt:output[rows] ) == 1,
              counter = counter + 1,
              If( counter > 0,
                     incr = (dt:output[Rows] - dt:output[Rows - counter - 1]) / (counter + 1);
                     For( i = Rows - counter, i <= Rows - 1, i++,
                           dt:output = dt:output[i - 1] + incr
                     counter = 0;
// Set all default referenced memory variables to this unique application
// Set the variable dt to be a pointer to the current active data table
// Loop through the data table from row 1 to the last row and use a
// variable names "rows" as the index
	// If this is row 1 initialize a variable named counter to 1
    // If the current row's value for the column named "Output" in the
	// data table referenced by "dt" is missing (blank, null) increase
	// the counter
		counter++
	// If row is found with a non missing value for the column called Output,
	// and the counter is > 0, which indicates previous rows with missing
	// values, then calculate the required values and place them in their
	// appropriate rows
	If( counter > 0 & Is Missing( dt:output[rows] ) == 0,
		// Calculate the incremental steps to use for the missing cells
		// Loop across the rows with missing values and fill in the data
			dt:output[i] = dt:output[i - 1] + incr
		// reinitialize the counter
		counter = 0;
ms
Super User (Alumni) ms
I had a similar problem some years ago and wrote a script to do imputation by "local regression".
Here's an updated version:
n = N Rows(dt);
x = Column(1);// Column("t")
For(i = 2, i <= N Col(dt), i++,
    y = Column(i);
    For Each Row(
        If(1 < Row() < n & Is Missing(y[]),
         // find previous non-missing row
            Eval(Eval Expr(r1 = Max(dt << get rows where(!Is Missing(y[]) & Row() < Expr(Row())))));
          // find next non-missing row
            Eval(Eval Expr(r2 = Min(dt << get rows where(!Is Missing(y[]) & Row() > Expr(Row())))));
            y[] = y[r1] + (y[r2] - y[r1]) / (x[r2] - x[r1]) * (x[] - x[r1]);
guilhem
Spot on MS,
Cheers!
tatersalad
txnelson,
could you update the script with comments? I am new to JSL and need help understanding how it applies to my problem. I have the same need as OP but only have one column that i need to fill in.  alternatively, I have used the following VBA code in the past in to fill in missing data in excel. I was wondering if there is something similar to the End(xlDown).value function in JSL. the offset is used to specify where the time point data is. Thanks!
Sub interpolatedata()
For Each cell In Range("k4:k29")
If cell.Value = "" Then
y2 = cell.End(xlDown).Value
x2 = cell.End(xlDown).Offset(0, -8).Value
y1 = cell.End(xlUp).Value
x1 = cell.End(xlUp).Offset(0, -8).Value
x = cell.Offset(0, -8).Value
y = (y1) + (x - x1) * (y2 - y1) / (x2 - x1)
cell.Value = y
End If
Here is an updated/annotated version of my original code.  All you should have to do, is to change the column name from "Output" to whatever the name of the column you want to change values to.
	// the counter
		counter++
	// appropriate rows
		counter = 0;
tatersalad
thanks it worked!  you commented
, did you mean "counter to 0"?
Good catch....it should be
If this is row 1 initialize a variable named counter to 0
