guilhem
Replacing missing data by regressed values
Hi
I have a time series for which the variable has missing values. I would like to replace the missing values by a linear model derived from the closest available values in time.
What would be the best way?
And if the script could do that to all the columns of my table (except the time), that would be even better
Thanks
Example
What I have
tOutput
010
10.
2010
What I want:
tOutput
010
115
220
430
1022.5
20
10
22 REPLIES 22
tatersalad
Re: Replacing missing data by regressed values
Jim,
is there a difference between "rows" and "Rows"? could you please explain it. I'm a noob.
JMP is not case specific in functions and statements, so rows=Rows
tatersalad
Jim,
Thank you for clarifying. I;m having a problem with the script. it wont execute and interpolate the last interval.  i cant tell if it has something to do with the nesting of the loops or the "while" conditions. basically regardless of table length it cant fill in the last interval of missing data.
col_name_list = Current Data Table() << get column names( string );
If( !Contains( col_name_list, "Interpolated p (g/L)" ),
	Current Data Table() << New Column(
		"Interpolated p (g/L)",
		Numeric,
		Continuous,
		Formula(
			If(
				Is Missing( :Name( "time (h)" ) ),
					Empty(),
				:name( "time (h)" ) == 0,
					0,
				!Is Missing( :Name( "p (g/L)" ) ),
				:name( "p (g/L)" ),
				dt = Current Data Table();
				For( rows = 1, rows <= (N Rows( dt )), rows++,
					If( Rows == 1, counter = 0 );
					If( Is Missing( dt:name( "Interpolated p (g/L)" )[rows] ) == 1,
						counter++);
					If( counter > 0 & Is Missing( dt:name( "Interpolated p (g/L)" )[rows] ) == 0,
						incr = (dt:name( "Interpolated p (g/L)" )[Rows] - dt:name( "Interpolated p (g/L)" )[Rows - counter - 1]) / (dt
						:name( "time (h)" )[Rows] - dt:name( "time (h)" )[Rows - counter - 1]);
						For( i = rows - counter, i <= rows - 1, i++,
							dt:name( "Interpolated p (g/L)" )[i] = dt:name( "Interpolated p (g/L)" )[i - 1] + (incr * (dt:name( "time (h)" )[i]
							-dt:name( "time (h)" )[i - 1]))
						counter = 0;
tatersalad
heres the table
You are running into a recursive issue in the formula, when you try to change values within the formula column itself.  I have reworked your formula to do all of the work upfront using a matrix.  The resulting values are then used for each rows values
	Current Data Table() << New Column( "Interpolated p (g/L)",
		Numeric,
		Continuous,
		Formula(
			If( Row() == 1,
				counter = 0;
				values = dt:Name( "p (g/L)" ) << get values;
				If( Is Missing( values[1] ),
					values[1] = 0
				counter = 0;
				For( i = 1, i <= N Rows( values ), i++,
					If( Is Missing( values[i] ),
						counter++,
						If( counter > 0,
							For( k = 1, k <= counter, k++,
								base = values[i - counter - 1];
								incr = Abs( (base - values[i]) / (counter + 1) );
								If( base < values[i],
									values[(i - counter - 1) + k] = base + k * incr,
									values[(i - counter - 1) + k] = base - k * incr
							counter = 0;
			values[Row()];
tatersalad
Jim,
Thanks so much i'll give it a shot. I'm curious though; going back to the original script i thought the recursive error came from row 3, because of it would go to calculate incr and get rows-counter-1 = 3-2-1 =0. i'd ignore the error message and it successfully interpolates the rest of the column, except for the very end.  adding more data to the table to be be interpolated moves the problem down. i thought they might be separate issues.
From my experiences, I have had too many issues when attempting to reference the actual formula column within the formula. Thus, the approach shown. I also was concerned with your formula from the standpoint of the number of times you are running through the data with your For() loop. My method steps through the data table only once....not counting the iteration replacement.
tatersalad
Jim,
I got the script to work. I had to add some math so as to account for the delta time for both the incr calculation for interpolation evaluation loop. final problem is that since i am planning on joining multiple run files together and running the script, I'll have multiple spots where time = 0 (time: 0,12,24,48,0,12,24,48...), thus the first interpolated value should be 0 for the given chunk of data. I'm not sure how to do this with the matrix notation.
From the code I supplied you, is this what you are asking about?
					values[1] = 0
tatersalad
that does it for the first value, but what i need is everything "Time" is 0, the interpolated value is zero. the time column will have multiple 0's
