twillkickers
Replace Third Character from Left in a String in JSL
I would like to take a column with a string in it, and in each row, replace the third character from the left with a "9." How might I go about this using JSL?
Re: Replace Third Character from Left in a String in JSL
Here is the simple script
dt = Current Data Table();
For Each Row(
	dt:YourColumn = Substr( dt:YourColumn, 1, Length( dt:YourColumn ) - 4 ) || "9" ||
	Right( dt:YourColumn, -2 )
I strongly suggest that you take the time to read the Scripting Guide, so that you will have the background knowledge that will allow you to solve these questions
