Thierry_S
Graph Builder: how to create plots with frame larger than the window size?
Hi JMP Community,
I need to create a large figures for a poster that ideally would need to be taller than the maximum frame size (on my system, it maxes out at 835). Is it possible to do so? I tried to force the vertical size of the frame via a script but I did not get what I wanted.
The alternative is to draw my plots at the maximum allowed size, export to EPS and rescale it to the desired vertical dimensions which is a bit of a drag considering that text gets messed up when exporting to EPS.
Any thoughts,
Thanks,
TS
Thierry R. Sornasse
Craige_Hales
Re: Graph Builder: how to create plots with frame larger than the window size?
this works by never using the display:
dt=open("$sample_data/big class.jmp");
nodisplay = borderbox(
dt<<Graph Builder(
	Size( 5180, 4480 ),
	Show Control Panel( 0 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 4 ) ), Smoother( X, Y, Legend( 5 ) ) )
nodisplay<<savepicture("$temp/deleteme.png","png");
nodisplay=0; // let go of the hidden report
pic=newimage("$temp/deleteme.png");
newwindow("x",pic);
show(pic<<size); // pic << size = {5304, 4518};
pic=0; // let go of the picture
deletefile("$temp/deleteme.png");
The platform uses the borderbox as its parent, and the JSL variable holds the borderbox. The window that opens with the picture has scroll bars; it is a static image of the live report that is not otherwise visible.
Craige
Another solution is to add:
Fit to Window("off")
to your Graph Builder script.  This will turn off the auto-stretching of the graph and still allow you to preview the result in a (scrollable) window.
Craige_Hales
dt<<Graph Builder(
	Size( 5180, 4480 ),
newwindow("x",pic);
Craige
